Some concerns with this dishwasher. 1, it will not clean the dishes, 2, bearing ring is worn and looks as if it needs to be replaced. 3, after seating the spray arm and screwing it down it wobbles badly, seams it should be much tighter than this.Dishes were hand cleaned and put in the washer for a rinse, and afterwards they had food debrea on the dishes. Also, machine appears to be filling correctly. Any suggestion to this delima? Than you. Max
