Hi I have a Kenmore Dishwasher serial number 665-16354300.The dishwasher keeps running on the wash cycle, have to manually stop it or it runs continuously. Any ideas?
Here are your parts Replacement parts for 665-16354300 models | AppliancePartsPros.comHere is a tech sheet, see the attachment. As you can see from the tech sheet it could be that the unit is trying to achieve a water temperature set point but is not getting there. Could be a bad heater, high-limit thermostat, thermistor or control board. I am assuming that every thing looks normal. Try a cycle where no heat is require. Does it now complete t he cycle? If yes then the above is probably happening. |
THIS FORUM IS DEAD!!!!!!! |
What is the Thermister? What does it do?
It is a solid state device that changes resistance with temperature (lowers resistance as temperature rises).
Tells the unit what the actual temperature is. |
