Dishwasher Repair
Stays in wash cycle.
Replacement parts for FRIGIDAIRE FDB1050REB2 Frigidaire/dishwasher | AppliancePartsPros.com Here is the tech sheet http://manuals.frigidaire.com/prodin.../154547901.pdf Often long wash times are due to the unit trying to reach a temperature set point and being unable to get there. Try a cycle that does not include water heating. Chjeck that the incoming water is at least 120 degrees F. Could be the heating element, the hi-limit thermostat, the thermistor or the control board. Try running diacnostics to see if that gives you some clues. |
I have a dishwasher Moder FDB1050REB2. The system is not working. We have check the electrical outlet and it has current. I think it might be the control panel. Is there anything else I can check before I order the part.
Thanks Al |
| All times are GMT -7. The time now is 06:33 AM. |
