4 Pages<1234>
abadfish66
#11 Posted : Friday, November 28, 2008 12:56:11 PM(UTC)
abadfish66
I think your problem is in the door switch. If it was anyother problem you would be getting an error "flashing light". Let me check something
abadfish66
#12 Posted : Friday, November 28, 2008 12:57:38 PM(UTC)
abadfish66
No not the delay start. after the lights go out, push a button to get the lights to come back on, at that point are you able to start it again?
abadfish66
#13 Posted : Friday, November 28, 2008 1:05:07 PM(UTC)
abadfish66
Press these buttons in this exact order. This will bring up the stored fault code if any, indicated by a blinking light.......
1. Heated dry
2.Fast wash
3.Super wash
4.Heated dry
5.Water temp
abadfish66
#14 Posted : Friday, November 28, 2008 1:08:27 PM(UTC)
abadfish66
You can press clear to exit out of service mode
abadfish66
#15 Posted : Friday, November 28, 2008 1:32:01 PM(UTC)
abadfish66
These are the fault codes if any are present......
Normal wash flashing = Not heating = less than 8 degree water temp rise in 15 minutes
Super wash flashing = over temp = water temp over 180
Fast wash blinking = Not filling
Rinse hold flashing = not draining
Heated dry flashing = over fill
kschneider
#16 Posted : Friday, November 28, 2008 1:48:36 PM(UTC)
kschneider
So, now what is happening (and the behavior seems a bit random), is that when the cycle stops, the lights go out, and then the key panel is totally unresponsive. I have to open and shut the door to get it to respond. When I do this, it seems like the dishwasher is back to the beginning of the cycle, when nothing has yet been pressed.
Actually, when I was testing it this time, I put the temperature on "sanitize" and the cycle actually proceeded past the "pre-wash" to "wash" for the first time. But when I opened the door, cleared it, and tried again, it got stuck before the wash cycle would begin, as usual.
abadfish66
#17 Posted : Friday, November 28, 2008 1:53:41 PM(UTC)
abadfish66
Do the test I posted earlier, post results. It does sound to me like your losing power, most likely at the door switch, could even be at the junction box where the house wiring connects to the dishwasher.
abadfish66
#18 Posted : Friday, November 28, 2008 1:55:22 PM(UTC)
abadfish66
Does the door handle feel like it's intact?
kschneider
#19 Posted : Friday, November 28, 2008 2:05:12 PM(UTC)
kschneider
When I press those 5 keys in rapid sequence, all the lights go off. No blinking, so I assume no fault codes.
kschneider
#20 Posted : Friday, November 28, 2008 2:05:52 PM(UTC)
kschneider
Yes, the door handle latches properly.
4 Pages<1234>
