Discuss
Door Leak
 in
Dishwasher Repair
In April 2006 our Whirlpool dishwasher started leaking water at the bottom right hand side of the door. It stopped
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Door Leak
  #1 (permalink)
Old 10-09-2007, 10:32 AM
Leon Wittner Leon Wittner is offline
Junior Member
Leon Wittner is on a distinguished road
Default Door Leak
Model Number: GU940SCGQ3   Brand: Whirlpool   Age: 5 - 10 years
In April 2006 our Whirlpool dishwasher started leaking water at the bottom right hand side of the door. It stopped leaking until recently and started again. Is this a door seal problem or could it be something else? Sometimes it is a smal drip and other times it leaks more. Is the door seal hard to replace and does it come with directions for replacement?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 02:16 PM
snakeman56 snakeman56 is offline
Junior Member
snakeman56 is on a distinguished road
Default Question
Did you ever find out what the problem was? Mine is doing the same thing! I just ordered the door gasket and see if that helps.
  #3 (permalink)
Old 12-31-2007, 04:13 PM
Junior Member
Default Leak cause identified
My leak was caused due to the pump cover shifting allowing water to blow out and spay up under the front of the door panel. I puled the spray arm off and removed the plastic cover from the pump well sump. There is a big rubber "O" Ring that had come out and was allowing the pressure to blow out instead of going to the upper spray arm. I reiserted the "O" Rong and put the top back on and it stopped the problem. Hope this helps you byt it fixed the problem for me. I did not need the new door seal but it is new anyway.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Leak BMcIntyre Refrigerator & Freezer Repair 0 10-02-2007 09:12 AM
Mystery Leak 2 LLcoolLutz Washer Repair 1 08-30-2007 03:17 PM
Leak LWEEKS Dishwasher Repair 1 08-30-2007 02:42 PM
Mystery Leak donnakay31 Washer Repair 2 08-14-2007 10:16 PM
Gas Leak fftpc Oven Repair (including Ranges and Cooktops) 2 08-08-2007 06:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
