STEVE DOE
#1 Posted : Friday, December 24, 2010 1:54:33 PM(UTC)
STEVE DOE
Found 1" water not draining after cycle. Blew out drain lines but then I found that I could not start the unit to check it. Have main power coming into unit but the control panel won't work and no lights illuminate. What could be the problem?
#2 Posted : Sunday, December 26, 2010 3:54:29 AM(UTC)
Replacement parts for KENMORE 66513592K600 | AppliancePartsPros.com
I am assuming that when you checked for power it was after the wirenuts that may connect the unit to the line.
It could be the thermal fuse is blown.
It is about a third of the way down the first page of the parts.
It is attached or on the control board.
If blown be sure to use the new harness which comes with the fuse.
Also check your door latch switches.
There seems to be a rash of units with no power, this is the third one I have seen today.
STEVE DOE
#3 Posted : Sunday, January 2, 2011 10:28:33 AM(UTC)
STEVE DOE
Originally Posted by: denman Go to Quoted Post
Is there a way to check the control fuse with a meter? I tried checking ohms and there was no continuity.
#4 Posted : Sunday, January 2, 2011 12:04:52 PM(UTC)
If there was no continuity it is open and blown.
