Discuss
Not draining...hose clear
 in
Dishwasher Repair
My dishwasher has been working great for years but stopped draining a few days ago. I have verified the drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Not draining...hose clear
  #1 (permalink)
Old 10-09-2007, 07:58 AM
mjpalad mjpalad is offline
Junior Member
mjpalad is on a distinguished road
Default Not draining...hose clear
Model Number: FDB421RFS4   Brand: Frigidaire   Age: 5 - 10 years
My dishwasher has been working great for years but stopped draining a few days ago. I have verified the drain hose is clear, air-gap is clear, hose from air-gap to garbage disposal is clear, and the knockout plug in the disposal has been correctly removed. My thinking is most likely the drain pump needs to be replaced.
The dishwasher does make a slightly different sound than it used to when it enters the drain cycle.
Anyone know of any other diagnosing I can do or other possible problems before I spend the money on a new drain pump?
Thanks in advance.
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 10-09-2007, 10:02 AM
lestouffer lestouffer is offline
Junior Member
lestouffer is on a distinguished road
Default
How did you check all these parts? I have a machine with the same problem, (but the noise is the same) and I figure it must be a blockage somewhere, but I cannot get to any of the obvious places to check it. Thanks
  #3 (permalink)
Old 10-09-2007, 11:15 AM
Junior Member
Default
Quote:
I knew the knockout plug in the garbage disposal was already out because it had previously drained correctly, and I haven't changed anything related to that. I unhooked the drain hose from the air gap and visually checked the air gap. I then had to pull the dishwasher out to unhook the drain hose from the dishwasher itself and run water through it to verify it was clear.
I'll let you know if the new drain pump makes a difference after I get the part replaced.
  #4 (permalink)
Old 10-16-2007, 04:43 PM
Junior Member
Default
Just to update, I got a used drain pump from a local used appliance store and that did the trick. It sure was satisfying to see that water start pumping.
  #5 (permalink)
Old 10-22-2007, 09:57 AM
Roshmm Roshmm is offline
Junior Member
Roshmm is on a distinguished road
Default Water Not draining (new washer)
I have the same problem (water not draining) since the washer is almost 12 years old I replaced it with a new one, but still the water does not drain. About a month back I have replaced the garbage disposal too. Did I have to do something with the garbage disposal unit?
Thanks,
Roshan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
manual clear stanleymnin Dishwasher Repair 0 06-27-2009 10:16 AM
clear ice cuber booie Refrigerator & Freezer Repair 0 03-30-2009 04:57 PM
Water but no ice getting made clear bin is empty shadivar Refrigerator & Freezer Repair 0 10-13-2008 08:18 AM
Control Lock will not clear Hagarr Dishwasher Repair 5 07-31-2008 07:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
