Discuss
Not draining...hose clear
 in
Dishwasher Repair
My dishwasher has been working great for years but stopped draining a few days ago. I have verified the drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Not draining...hose clear
  #1 (permalink)
Old 10-09-2007, 08:58 AM
mjpalad mjpalad is offline
Junior Member
mjpalad is on a distinguished road
Default Not draining...hose clear
Model Number: FDB421RFS4   Brand: Frigidaire   Age: 5 - 10 years
My dishwasher has been working great for years but stopped draining a few days ago. I have verified the drain hose is clear, air-gap is clear, hose from air-gap to garbage disposal is clear, and the knockout plug in the disposal has been correctly removed. My thinking is most likely the drain pump needs to be replaced.
The dishwasher does make a slightly different sound than it used to when it enters the drain cycle.
Anyone know of any other diagnosing I can do or other possible problems before I spend the money on a new drain pump?
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-09-2007, 11:02 AM
lestouffer lestouffer is offline
Junior Member
lestouffer is on a distinguished road
Default
How did you check all these parts? I have a machine with the same problem, (but the noise is the same) and I figure it must be a blockage somewhere, but I cannot get to any of the obvious places to check it. Thanks
  #3 (permalink)
Old 10-09-2007, 12:15 PM
Junior Member
Default
Quote:
I knew the knockout plug in the garbage disposal was already out because it had previously drained correctly, and I haven't changed anything related to that. I unhooked the drain hose from the air gap and visually checked the air gap. I then had to pull the dishwasher out to unhook the drain hose from the dishwasher itself and run water through it to verify it was clear.
I'll let you know if the new drain pump makes a difference after I get the part replaced.
  #4 (permalink)
Old 10-16-2007, 05:43 PM
Junior Member
Default
Just to update, I got a used drain pump from a local used appliance store and that did the trick. It sure was satisfying to see that water start pumping.
  #5 (permalink)
Old 10-22-2007, 10:57 AM
Roshmm Roshmm is offline
Junior Member
Roshmm is on a distinguished road
Default Water Not draining (new washer)
I have the same problem (water not draining) since the washer is almost 12 years old I replaced it with a new one, but still the water does not drain. About a month back I have replaced the garbage disposal too. Did I have to do something with the garbage disposal unit?
Thanks,
Roshan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
my washer stopped draining or spining jesse Washer Repair 1 10-09-2007 03:16 AM
dishwasher draining all the time kevintooley Dishwasher Repair 1 09-19-2007 07:02 PM
front loader not draining distress Washer Repair 1 09-14-2007 03:24 AM
Water Is Draining As It Fills jbgreer Washer Repair 2 09-03-2007 11:52 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
