Discuss
GE - Solenoid Function?
 in
Dishwasher Repair
D/W won't drain. Last time, several months ago, I found the piston/nut in hideous condition. Replaced it. Flapper valve was
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE - Solenoid Function?
  #1 (permalink)
Old 11-23-2008, 11:17 AM
jpa jpa is offline
Junior Member
jpa is on a distinguished road
Default GE - Solenoid Function?
Model Number: 5134   Brand: -brand-   Age: Less than 1 year
D/W won't drain. Last time, several months ago, I found the piston/nut in hideous condition. Replaced it. Flapper valve was fine. Unit worked great. Now it isn't draining again. I ran the test cycles and when I manually put it to the last step, draining, the drain pump runs and the tank empties perfectly. When a cycle runs it does not empty at all, just a little trickle. The difference between the two is the normal cycle, on drain, the main motor is still running and the solenoid pulls in. In the test cycle only the little drain pump is running and the solenoid is not energized. Thoughts? And, no, I have not checked the two valves (yet). What does the solenoid do? My guess is that with the main pump running maybe there is some pressure holding open the return valve from the collection chamber back into the tub?
Related Models
Hoover 5137
Frigidaire 5137006A AIR CONDITIONING 5200 B.T.U.
Frigidaire 5137007E1 AIR CONDITIONER
Frigidaire 5138007 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5138007E AIR CONDITIONER
Frigidaire 5138007G1 AIR CONDITIONER
Frigidaire 5139008 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008A FRIGIDAIRE AIR CONDITIONER
Frigidaire 5139008E1 AIR CONDITIONER
Frigidaire 5139A AIR CONDITIONER
Hoover 5140
Frigidaire 5144000 AIR CONDITIONER
Frigidaire 5144000B AIR CONDITIONER
Frigidaire 5145001 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5145001B AIR CONDITIONER
Hoover 5146
Frigidaire 5146002 AIR CONDITIONER
Frigidaire 5146002A AIR CONDITIONER
Frigidaire 5147003 FRIGIDAIRE AIR CONDITIONER
Hoover 5148
Frigidaire 5148004A AIR CONDITIONER
Frigidaire 5148004E FRIGIDAIRE ROOM AIR CONDITIONER
Frigidaire 5149A AIR CONDITIONER
Amana 515.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 5150
Frigidaire 5154007 AIR CONDITIONER
Hoover 5158
Hoover 5158-01
Frigidaire 5159B AIR CONDITIONER
Hoover 5160
Frigidaire 5164004 AIR CONDITIONER
Frigidaire 5167A AIR CONDITIONER
Frigidaire 5167B AIR CONDITIONER
Hoover 5168
Hoover 5168-01
Frigidaire 5169B AIR CONDITIONER
Frigidaire 5174001 AIR CONDITIONER
Frigidaire 5174001B AIR CONDITIONER
Frigidaire 5176003A ROOM AIR CONDITIONER
Frigidaire 5177004A AIR CONDITIONER
Frigidaire 5177004B AIR CONDITIONER
Frigidaire 5178A AIR CONDITIONER
Frigidaire 5179A AIR CONDITIONER
Frigidaire 5179B AIR CONDITIONER
Frigidaire 5180004 WESTINGHOUSE AIR CONDITIONER
Frigidaire 5180004A AIR CONDITIONER
Frigidaire 5187A AIR CONDITIONER
Frigidaire 5187B AIR CONDITIONER
Frigidaire 5187C AIR CONDITIONER
Frigidaire 5193004 AIR CONDITIONER
Frigidaire 5193004A AIR CONDITIONER
Frigidaire 5193004B AIR CONDITIONER
Frigidaire 5195006 FRIGIDAIRE AIR CONDITIONER
Frigidaire 5195006A AIR CONDITIONER
Frigidaire 5197A AIR CONDITIONER
Frigidaire 5198A AIR CONDITIONER
Frigidaire 5198B AIR CONDITIONER
Frigidaire 5198C AIR CONDITIONER
Frigidaire 5198G AIR CONDITIONER
Magic Chef 51FA-1K RANGE- D/I STD GAS
Magic Chef 51FA-1KXS-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FA-2KW RANGE- D/I STD GAS
Magic Chef 51FA-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FA-2KX-ON RANGE- D/I STD GAS
Magic Chef 51FA-2KXS-ON RANGE- D/I STD GAS
Magic Chef 51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef 51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-1K RANGE- D/I STD GAS
Magic Chef 51FN-1KX RANGE- D/I STD GAS
Magic Chef 51FN-2KLX-ON RANGE- D/I CONT CLEAN GAS
Magic Chef 51FN-2KW RANGE- D/I STD GAS
Magic Chef 51FN-2KW-BS RANGE- D/I STD GAS
Magic Chef 51FN-2KX-ON RANGE- D/I STD GAS
Magic Chef 51FY-2KLX-ON RANGE- D/I CONT CLEAN GAS
Whirlpool 51IMWEX1 FREESTANDING ICE MAKER
Amana 520.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 520.001 MWAVE - FAMILY SIZE (60 HZ)
Hoover 5200
Frigidaire 5237A AIR CONDITIONER
Frigidaire 5238A AIR CONDITIONER
Hoover 5240
Frigidaire 5243000 AIR CONDITIONER
Frigidaire 5243000A AIR CONDITIONER
Frigidaire 5243000B AIR CONDITIONER
Frigidaire 5244001A ROOM AIR CONDITIONER
Frigidaire 5249A AIR CONDITIONER
Frigidaire 5249G AIR CONDITIONER
Frigidaire 5257A AIR CONDITIONER
Frigidaire 5257B AIR CONDITIONER
Frigidaire 5257C AIR CONDITIONER
Frigidaire 5257D AIR CONDITIONER
Frigidaire 5257G AIR CONDITIONER
Frigidaire 5263004 AIR CONDITIONER
Frigidaire 5263004A AIR CONDITIONER
Frigidaire 5263004B AIR CONDITIONER
Frigidaire 5277A ROOM AIR CONDITIONER
Frigidaire 5277C AIR CONDITIONER
Frigidaire 5277D AIR CONDITIONER
Frigidaire 5287A AIR CONDITIONER
Frigidaire 5288A AIR CONDITIONER
Frigidaire 5289A AIR CONDITIONER
Frigidaire 5291003 AIR CONDITIONER
Frigidaire 5291A AIR CONDITIONER
Frigidaire 5292004A AIR CONDITIONER
Frigidaire 52HA52C
Hoover 53
Hoover 5300
Hoover 5308
Hoover 5308-01
Frigidaire 5317A AIR CONDITIONER
Frigidaire 5317C AIR CONDITIONER
Frigidaire 5317D AIR CONDITIONER
Frigidaire 5318A AIR CONDITIONER
Frigidaire 53251-0E FREEZER
Frigidaire 5328002B ROOM AIR CONDITIONER
Frigidaire 5330A AIR CONDITIONER
Frigidaire 5337A AIR CONDITIONER
Frigidaire 5337B AIR CONDITIONER
Frigidaire 5338009 AIR CONDITIONER
  #2 (permalink)
Old 11-23-2008, 02:51 PM
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
We NEED a COMPLETE Model# off the unit, not the book, I don't remember seeing a GE DW with BOTH a drain pump and a drain solonoid!!!
__________________
  #3 (permalink)
Old 11-24-2008, 10:03 PM
jpa jpa is offline
Junior Member
Default
Quote:
I am not at home now and do not have the model # beyond what is listed. There most definitely is a second pump, unless I am confusing the main motor as being connected to a pump as well? To what else would this main motor be connected? When in the test modes, all mid-sequence steps that do a drain action, the main pump runs and the solenoid pulls in. There is little or no draining when this is going on. The very last step, the main pump shuts off, the solenoid is not pulled in and only the little drain pump runs. I have not measured to see if power is being applied to the small pump when these intermediate test steps are running.
  #4 (permalink)
Old 11-25-2008, 12:29 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is a thread from another forum which closely matches your situation.
Appliance Tech\'s Private Board >> GE Dishwasher Drain Problems
It seems that the flapper valve solenoid and the drain pump should both be energized. Looks like the pump just helps the main motor / flapper valve a little.
The flapper valve directs the water to the drain instead of up to the wash arms.
It receives about a 10 second pulse from the timer, once the solenoid/flapper is in the drain position the force of the water keeps it in the drain position until the unit is empty.
Take a look under the unit for the wiring diagram. It should have a timing chart. Could be taped to the tud or the back of the kick plate.
__________________
  #5 (permalink)
Old 11-25-2008, 01:06 PM
jpa jpa is offline
Junior Member
Default
Quote:
Originally Posted by denman View Post
...Take a look under the unit for the wiring diagram. It should have a timing chart. Could be taped to the tud or the back of the kick plate.
Thanks, I think I am getting a feel for its operation. The small pump apparently is used to empty the sump out? That is the impression I am getting from what info I can find. When I do a 'test' run (rinse only) I haven't noticed the little pump coming on at the end (to empty the sump), which would be witnessed by a short burst of water in the drain. It seems logical that the small pump is indeed a 'boost' to get the flapper seated properly. I will have to pull the main pump off and see what I can find. I didn't see any actual timings in the tech sheet I pulled from under the tub. The only timings it listed were in the test modes. If the test modes are indicative of the actual cycle times, there were two drains in the middle that were I think 60 seconds and then the very final one, using the small pump, of 70 seconds. I am curious as to the 'circuitry' of the drain system. It looks like the small pump pulls from the sump right into the collection chamber. I guess this then forces the spring loaded collection valve shut and diverts to the drain port.
  #6 (permalink)
Old 12-05-2008, 10:14 AM
jpa jpa is offline
Junior Member
Default
OK, I am back in country. Pulled apart the the D/W and found the flapper valve on the second drain pump ("dual pump" in GE-speak) was totally missing. I guess this is it - when the solenoid pulls in all the water runs through the drain pump back into the tank - there isn't any back pressure to force the valve closed in the collection box.
I've ordered one and will report back if it is not the cause.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave will not function at all dodie1019 Microwave Repair 0 12-28-2009 11:07 AM
Control pad won't function tinker411 Oven Repair (including Ranges and Cooktops) 0 11-27-2009 09:27 AM
Toe bar on Kitchenaid won't function Bubba1 Trash Compactor Repair 0 08-30-2009 09:52 PM
Dishwasher Will Not Function chill691 Dishwasher Repair 0 08-23-2009 08:31 PM
Whirlpool F6 Function? patespy Microwave Repair 1 03-07-2009 11:51 AM
