| » Squeeky agitator |
Model Number: AAV7000AWW Brand: Admiral Age: Less than 1 year
When agitating, the machine squeeks at the moment it changes direction. It sounds like either a belt or plastic part rubbing and/or losing grip. I can cause it to repeat this when I have the top off and manually move the drum. However, I have not found an actual belt on the machine and do not know how to take the agitator off to check further. Does anyone know where a manual canbe found... or the solution?
thanks much... Bill McGuire Related Models |
If you have the top off, remove the front panel as well and you can see under the tub.
nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Thanks for the info...
I had the front off and did notice a thick rubber bushing that the tub went through. I used a silicone spray on it and th noise has subsided. I'll spray it a couple more times to see it it disappears... Thanks again... |
| Display Modes | |
| Kenmore washer 80 top agitator does not move with bottom agitator | erbaker | Washer Repair | 1 | 02-19-2008 12:11 PM |
| agitator | hurst | Washer Repair | 2 | 12-13-2007 06:22 PM |
| Mover Agitator Came Off The Agitator | memmie | Washer Repair | 2 | 11-16-2007 07:41 PM |
| Top Agitator came apart from the bottom Agitator | memmie | Washer Repair | 1 | 11-15-2007 10:06 PM |
| Top agitator on duel agitator not working | bigfoot | Washer Repair | 1 | 10-28-2007 06:34 AM |
