Discuss
drains through overflow
 in
Dishwasher Repair
dishwasher drains through overflow and makes a mess on counter. why dont it drain through hose that goes to garbage
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » drains through overflow
  #1 (permalink)
Old 12-18-2010, 02:13 PM
Junior Member
cmoore96er@yahoo.com is on a distinguished road
Default drains through overflow
Brand: -brand-   Age: Less than 1 year
dishwasher drains through overflow and makes a mess on counter. why dont it drain through hose that goes to garbage disposal
  #2 (permalink)
Old 12-19-2010, 01:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I am assuming you are referring to an air gap. This is not an overflow device.
What it does is allow air into the drain hose when the drain cycle stops. This prevents the drain hose from siphoning water back into the machine.
It could be that there is a plug between the air gap and the house drain.
Remove the hose and check it.
It could be that the air gap needs replacing as normally it is supposed to seal the water in.
I am assuming that this installation used to run OK. If the garbage disposal is new you may have forgotten to knock out the plug on the disposal.
Here is a good dishwasher install sheet so you can see how it should be plumbed.
http://products.geappliances.com/Mar...e=31-30515.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker overflow Cbockmiller Refrigerator & Freezer Repair 9 02-09-2010 01:05 PM
Washer overflow nightglow1 Washer Repair 2 01-13-2010 01:36 PM
overflow tpeacher@gloomis.com Washer Repair 2 05-25-2009 12:58 PM
overflow Joesquich Washer Repair 2 03-30-2009 12:14 PM
Overflow Gary V Washer Repair 1 01-09-2008 12:27 PM
