| » Kenmore won't fill, just heats up |
Model Number: ultra wash quiet guard delux Brand: Kenmore Age: 1 - 5 years
The water dept was here yesterday checking the meter. We had air in the pipes after, but all seemed okay. When I started the dishwasher, it made noise and I thought it was okay but after a while I noticed it sounded a little different. I opened it and realized that it was hot but there was no water in it. I cancelled the cycle and have since tried it a few more times with no luck. I poured some water in it and it drained fine. Could this have something to do with it resetting b/c air in the pipes or something? Thanks for the help!!!
Please post your model number.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Yes it may be connected, pretty big coincidence if it isn't but stranger things have happened.
Remove the kick plate and check to see if the water inlet valve is getting voltage when it should. Remove the wires from the valve and check if it has continuity. If OK loosen the inlet side connection on the water valve till it starts to drip. Then tighten it back up and give it a try. If still no go remove the water valve and check that the inlet screen filter in the valve is clean. Especially if you have noticed another tap etc. is not working OK now. perhaps the water dept. knocked some crud loose from the pipes.
__________________
The model number will be on the dishwasher itself, open the door and look around the frame.
Nat
__________________
Check your fill valve for any debris, when they were working on your water meter they may have gotten stuff in the lines. If need the part number is AP3866790
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com Last edited by libertyappl : 11-21-2008 at 01:06 PM. |
| Display Modes | |
| Kenmore Dyer Heats, But Then Quits | rbautch | Dryer Repair | 3 | 01-01-2010 12:36 PM |
| Kenmore Elite dryer heats then stops | toothfxr | Dryer Repair | 0 | 09-06-2009 08:12 AM |
| Kenmore gas dryer starts, heats, shuts off early | jcpendergast | Dryer Repair | 2 | 08-17-2009 02:25 PM |
| Kenmore 110 gas dryer heats intermitt | wolf8963 | Dryer Repair | 7 | 08-05-2009 04:08 AM |
| Kenmore dryer heats okay but slows then stops | Espritman | Dryer Repair | 7 | 07-24-2009 01:36 PM |
