mbleskin
#1 Posted : Wednesday, December 15, 2010 10:28:25 AM(UTC)
mbleskin
Hi - I'm getting no heat from my dishwasher to either heat water or to dry (at any time/during the dry cycle). The element does not heat at any point during the cycle. The unit is running fine except that it is also sticking at about 6 o'clock on the timer. I think this has to do with the heat issue. I'm wonder if I have a faulty thermostat or heat element. I have not tested either. Any advice on this issure with this unit? The unit was running completely fine up until a week ago and no installation changes were made or done.
I guess I was hoping that the heat element would go on if I manually set it to the 'dry' part of the cycle (thus eliminating faulty element).
New to this, so any help/insight is much appreciated.
Thanks,
Matt
#2 Posted : Thursday, December 16, 2010 1:24:02 AM(UTC)
Replacement parts for FRIGIDAIRE FDB421RFS1 Frg(v2) / Built - in Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154295401.pdf
The heater circuit involves 3 parts.
Heat element (Item 1 in Section 4) should be 10 ohms approx.
Hi-limit thermostat (Item 29 in Section 3) should be 0 ohms
Timer (Item 3 in Section 1)
Best way to check the heat element and hi-limit thermostat is to remove power from the unit and use a meter.
If both are OK get back to us on how to check the timer.
mbleskin
#3 Posted : Thursday, December 16, 2010 6:38:09 AM(UTC)
mbleskin
Thanks.
Tested and the thermostat looks bad. I got an open reading and from what i've researched this should be closed until high temp activiated.
-Matt
