Discuss
Bosch On/Off Button&Switch Replacement
 in
Dishwasher Repair
I need to replace the On/Off Power button & switch which is located on the top edge of the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch On/Off Button&Switch Replacement
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-08-2007, 11:59 AM
dkh dkh is offline
Junior Member
dkh is on a distinguished road
Default Bosch On/Off Button&Switch Replacement
Model Number: SHY56A05UC/14   Brand: Bosch   Age: 1 - 5 years
I need to replace the On/Off Power button & switch which is located on the top edge of the door. What is the correct method to disassemble the door to replace the button and switch? I would rather not remove the inside panel if I don't have to. Thanks for your help. Cheers.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-05-2007, 06:36 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
the inside panel does not come off easy the ouside panel comes off and should be able to access the switch from the front and also bosch like to use a lot of clips so take time and look at it good
  #3 (permalink)
Old 12-02-2007, 04:19 PM
Freddy C Freddy C is offline
Junior Member
Freddy C is on a distinguished road
Default
I have the same problem with the power switch. I took off the plastic cover for the controls and the outside panel. I see the switch and was able to release it from the mounting..However I don't see how to get it out of the space it is in. It has a rod going to the center door latch and a plunger that pushes the on/off switch. there must be some trick to remove the switch from the machine to replace it. If you know how please email me at kidcarr.jr@verizon.net Thank you...
  #4 (permalink)
Old 12-13-2007, 08:01 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
many different models and several different procedures... Integrated models with controls on the top are different from d/w's with controls on the front ... definitely need torx t-20 screwdriver... door panel comes off readily easy (3 lowest screws, on either side starting closest to the hinge , working your way up ... after that it is just a matter of taking control panel off , manipulate metal tab to remove on/off switch ...
kawfeeman@hotmail.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 05:04 PM
Hum when start button is pushed LOST Dryer Repair 1 10-01-2007 03:59 PM
Dryer start button Yorba Dryer Repair 1 08-13-2007 05:13 PM
Dryer stops running after letting off the Start button Andy Dryer Repair 10 08-01-2007 09:56 PM
Lid Switch CAN I DO IT Washer Repair 0 07-24-2007 04:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
