Hi, We have a Whirlpool dishwasher (Model #DU110XTPBA) that makes very loud noises when running the wash cycle. After reviewing some other posts I have inspected the chopper assembly to see if there is some broken glass or other debris that might be causing the noise but I found no debris. Is there anything else I should try or am I at the point where I need to consider replacing the main motor or the entire dishwasher? Any help would be appreciated and I look forward to your response. Sincerely, Brad S.
