Discuss
Pump Assembly leak
 in
Dishwasher Repair
I water dripping from my pump housing. Will a new housing repair the leak or do I need to order
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Pump Assembly leak
  #1 (permalink)
Old 12-05-2010, 12:17 PM
Junior Member
depepper1 is on a distinguished road
Default Pump Assembly leak
Model Number: DU840CWDQ3   Brand: Whirlpool   Age: More than 10 years
I water dripping from my pump housing. Will a new housing repair the leak or do I need to order the pump moter and assembly?
Ads By Google
Related Models
Whirlpool DU840CWDQ3
Whirlpool DU840CWDQ4
Whirlpool DU840CWDQ5
Whirlpool DU840DWGQ0
Whirlpool DU840DWGQ1
Whirlpool DU840DWGQ2
Whirlpool DU840DWGT2
Whirlpool DU840DWGX0
Whirlpool DU840DWGX1
Whirlpool DU840DWGX2
Whirlpool DU840DWGZ0
Whirlpool DU840DWGZ1
Whirlpool DU840DWGZ2
Whirlpool DU840SWKQ0
Whirlpool DU840SWKT0
Whirlpool DU840SWKU0
Whirlpool DU840SWKX0
Whirlpool DU840SWLQ0 Undercounter Dishwasher
Whirlpool DU840SWLT0 Undercounter Dishwasher
Whirlpool DU840SWLU0 Undercounter Dishwasher
Whirlpool DU840SWPQ0 Undercounter Dishwasher
Whirlpool DU840SWPQ1 Undercounter Dishwasher
Whirlpool DU840SWPQ2 Undercounter Dishwasher
Whirlpool DU840SWPS0 Undercounter Dishwasher
Whirlpool DU840SWPS1 Undercounter Dishwasher
Whirlpool DU840SWPS2 Undercounter Dishwasher
Whirlpool DU840SWPT0 Undercounter Dishwasher
Whirlpool DU840SWPT1 Undercounter Dishwasher
Whirlpool DU840SWPT2 Undercounter Dishwasher
Whirlpool DU840SWPU0 Undercounter Dishwasher
Whirlpool DU840SWPU1 Undercounter Dishwasher
Whirlpool DU840SWPU2 Undercounter Dishwasher
Whirlpool DU8450XB0
Whirlpool DU8450XB1
Whirlpool DU8500XB0
Whirlpool DU8500XB1
Whirlpool DU8500XT0
Whirlpool DU8500XT1
Whirlpool DU8500XT2
Whirlpool DU8500XT3
Whirlpool DU8500XT4
Whirlpool DU8500XT5
Whirlpool DU8500XX0
Whirlpool DU8500XX1
Whirlpool DU8500XX2
Whirlpool DU8500XX3
Whirlpool DU8500XX4
Whirlpool DU850DWGB0
Whirlpool DU850DWGB1
Whirlpool DU850DWGQ0
Whirlpool DU850DWGQ1
Whirlpool DU850DWGX0
Whirlpool DU850DWGX1
Whirlpool DU850SWKB0
Whirlpool DU850SWKQ0
Whirlpool DU850SWKT0
Whirlpool DU850SWLB0 Undercounter Dishwasher
Whirlpool DU850SWLQ0 Undercounter Dishwasher
Whirlpool DU850SWPB0 Undercounter Dishwasher
Whirlpool DU850SWPB1 Undercounter Dishwasher
Whirlpool DU850SWPB2 Undercounter Dishwasher
Whirlpool DU850SWPB3 Undercounter Dishwasher
Whirlpool DU850SWPQ0 Undercounter Dishwasher
Whirlpool DU850SWPQ1 Undercounter Dishwasher
Whirlpool DU850SWPQ2 Undercounter Dishwasher
Whirlpool DU850SWPQ3 Undercounter Dishwasher
Whirlpool DU850SWPS0 Undercounter Dishwasher
Whirlpool DU850SWPS1 Undercounter Dishwasher
Whirlpool DU850SWPS2 Undercounter Dishwasher
Whirlpool DU850SWPS3 Undercounter Dishwasher
Whirlpool DU850SWPT1 Undercounter Dishwasher
Whirlpool DU850SWPT2 Undercounter Dishwasher
Whirlpool DU850SWPT3 Undercounter Dishwasher
Whirlpool DU850SWPU0 Undercounter Dishwasher
Whirlpool DU850SWPU1 Undercounter Dishwasher
Whirlpool DU850SWPU2 Undercounter Dishwasher
Whirlpool DU850SWPU3 Undercounter Dishwasher
Whirlpool DU851SWPS0 Undercounter Dishwasher
Whirlpool DU851SWPS1 Undercounter Dishwasher
Whirlpool DU851SWPS2 Undercounter Dishwasher
Whirlpool DU8530XX0
Whirlpool DU8530XX1
Whirlpool DU8550XB0
Whirlpool DU8550XB1
Whirlpool DU8550XT0
Whirlpool DU8550XT1
Whirlpool DU8550XT2
Whirlpool DU8550XT3
Whirlpool DU8550XT4
Whirlpool DU8550XT5
Whirlpool DU8550XX0
Whirlpool DU8550XX1
Whirlpool DU8550XX3
Whirlpool DU8550XX4
Whirlpool DU8560XB0
Whirlpool DU8560XB1
Whirlpool DU8560XX0
Whirlpool DU8560XX1
Whirlpool DU8560XX2
Whirlpool DU8570XT0
Whirlpool DU8570XT1
Whirlpool DU8570XT2
Magic Chef DU85CA-01 Dishwasher - Undercounter
Magic Chef DU85CA-02 Dishwasher - Undercounter
Magic Chef DU85CA-20 Dishwasher - Undercounter
Magic Chef DU85DA-25 Dishwasher - Undercounter
Magic Chef DU85DA-35 Dishwasher - Undercounter
Magic Chef DU85DA-45 Dishwasher - Undercounter
Magic Chef DU85DA-48 Dishwasher - Undercounter
Magic Chef DU85DN-35 Dishwasher - Undercounter
Whirlpool DU860SWSB0 Undercounter Dishwasher
Whirlpool DU860SWSQ0 Undercounter Dishwasher
Whirlpool DU860SWSS0 Undercounter Dishwasher
Whirlpool DU8700XB0
Whirlpool DU8700XB1
Whirlpool DU8700XT0
Whirlpool DU8700XT1
Whirlpool DU8700XT2
Whirlpool DU8700XT3
Whirlpool DU8700XT4
  #2 (permalink)
Old 12-06-2010, 02:47 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL DU840CWDQ3 | AppliancePartsPros.com
Will a new housing repair the leak or do I need to order the pump motor and assembly?
Only you can answer that question.
You have to figure out where the leak is coming from.
If the pump housing is cracked then replacing it would repair the problem.
I would also replace the motor seals. I would get Item 9 in section 5 as it looks like it includes both seals and the impeller.
If it is just leaking from the motor to the housing then odds are a seal kit would fix this.
It is often difficult to find the actual leak location because the water can run down the parts till it drips off so often the actual leak is higher up.
A small mirror and a flashlight can help locate a leak. An ideal mirror is the type used by mechanics witch has a small mirror mounted on an extendable handle. You could always just tape a mirror on the ned of a stick if you have to.
Note: It is a good idea to add a quart or two of water to the unit before firing it up. Dishwasher pumps do not like to run totally dry.
__________________
  #3 (permalink)
Old 12-06-2010, 08:55 AM
Junior Member
Default Leak Location
It is leaking where the impellor comes through the housing and connects to the pump motor.
  #4 (permalink)
Old 12-06-2010, 10:10 AM
Senior Expert
APP Volunteer
Default
Then I would say the below should fix the problem.
Part number: AP3108052
As long as the motor's shaft is OK.
This should help with the repair
https://secured.whirlpool.com/Servic...LE/4322430.pdf
__________________
  #5 (permalink)
Old 12-06-2010, 11:49 AM
Junior Member
Default Parts Ordered
Thanks for the reply and I have ordered a new housing and seal kit. I will be fixing it this week
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installed new pump has leak vargo Dishwasher Repair 0 09-17-2010 05:30 AM
replace motor-pump assembly russtodd Dishwasher Repair 6 04-16-2009 11:14 PM
leak from pump screws altaub Dishwasher Repair 0 03-25-2009 07:23 PM
Pump and Motor Assembly Saw Man Dishwasher Repair 1 03-24-2009 07:31 AM
Leak down float assembly David Maheu Dishwasher Repair 1 10-24-2007 02:10 AM
