| » Part Identification Question |
Model Number: FDB857RJB0 Brand: Frigidaire Age: 5 - 10 years
This is in reference to a Frigidaire Dishwasher Model # FDB857RJB0. I am attempting to replace a couple of worn nylon rollers (rack support) on the diswasher tub wall. The screw which attaches them is not a standard screw head configuration. I assume it may be a Torx head screw but am not certain. Can anyone identify the precise type and size for me as I will probably need to purchase a driver to fit them? Thank you.
I cannot tell you what size it is but if I was you I would buy a set with an inter changeable handle. A set with 5 to 10 Torx with the one you need in it should not be that expensive.
The next time you need a Torx odds are it would not be the size you bought. Also try to get the security type re: there is a hole in the center of the bit. Manufacturer's are staring to use a Torx that has a pin in the center so that a normal Torx will not fit in. I have a set with a two way handle, 8 Torx and two flat and Phillips bits that set me back about $10.00.
__________________
| Display Modes | |
| Need identification of Part #330 spring | barb4055 | Refrigerator & Freezer Repair | 0 | 08-24-2010 05:40 PM |
| Part Identification Help | tedbalog | Washer Repair | 1 | 04-11-2010 08:47 AM |
| Replacement Part Identification | tyr67360 | Washer Repair | 3 | 03-03-2009 07:17 PM |
| Question About Part | KYY | Oven Repair (including Ranges and Cooktops) | 1 | 01-05-2009 07:28 AM |
| Part compatibility question | tstanke | Dishwasher Repair | 2 | 11-20-2008 08:48 AM |
