Discuss
dishwasher will drain but will not fill with water
 in
Dishwasher Repair
I'm not very good at repairs, but the diswaher did work when I took it out. When I put it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher will drain but will not fill with water
  #1 (permalink)
Old 12-04-2010, 09:26 AM
Junior Member
pap954 is on a distinguished road
Default dishwasher will drain but will not fill with water
Brand: Sears   Age: 1 - 5 years
I'm not very good at repairs, but the diswaher did work when I took it out. When I put it back in the diswaher will only drain. It will not wash and does not seem to be getting any water in it......I read some of the other users problems and I read about a float valve. Can you tell me where I might find it on a sears dishwasher? I can not find the serial number but it does have ultra quiet washer on the front.
Ads By Google
  #2 (permalink)
Old 12-05-2010, 02:31 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
This may help find the model number
Model Number Locator
The float will be a small tower inside the tub usually towards the front of the tub.
If you remove the kick plate you will see the switch that it operates mounted under the tub/float assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher won't fill with water Tru2Chevy Dishwasher Repair 5 12-21-2011 05:23 AM
will fill up with water but wont agitate, spin or drain mattdragg Washer Repair 1 10-25-2010 08:07 AM
washer will only fill with water, won't agitate, spin, drain, etc. patsz26 Washer Repair 3 06-02-2010 09:13 PM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Only on rinse cycle washer won't fill up with water, goes right to the drain hose pmmcadams Washer Repair 1 08-10-2009 03:33 PM
