My oven will not heat up unless I ignite a top burner. Then it will reach the set temperature. However, after it has reached that temp. it will cool down unless I start all over by pushing bake-temp-light a burner. From my research so far, it looks like I need to replace the oven ignitor or bake ignitor. Is there a difference? This site only gave a part option for the oven ignitor. Any other possibilities on the what is problem is?
