| » Cycle hangs before final rinse |
Model Number: DWU7550AAX Brand: Maytag Age: 5 - 10 years
The dishwasher hangs prior to the final rinse cycle with the Temp Boost Sensor on. If the sensor is off, the dishwasher will run a complete cycle normally. I have replaced the timer but that did not solve the problem. Any help will be greatly appreciated. Thanks.
Thats normal because its heating water and depending on how hot the water coming out of hot water tank and the temp enetering machine will determine how long machine stalls remember water is just trickling on element not like setting a pot of water on the stove and boiling it. I would say it's working as designed
__________________
You said it hangs but did not say for how long.
Here is a service manual which should help http://www.servicematters.com/maytag...s/16007823.pdf Check that you are getting the correct water level Page 3-31 Could be it is just low and the water is not heating correctly. Most likely cause of this would be a partially clogged screen filter on the inlet valve. Could also be a bad sensor Page 2-22 OR as V2K04 said it may be normal operation.
__________________
Denman,
In answer to your question, it hangs forever. However, I was able to solve the problem. It turns out that one of the connectors to a thermostat was disconnected. The service manual was a big help in identifing the problem. Thanks for your help. Kapl |
| Display Modes | |
| DW hangs up in wash/rinse cycles | OrvD | Dishwasher Repair | 16 | 02-08-2012 03:31 PM |
| washer hangs during cycle | kevinjmaz | Washer Repair | 1 | 02-15-2010 11:43 AM |
| Maytag neptune with no final rinse | stinchi | Dishwasher Repair | 0 | 08-23-2009 02:01 PM |
| Washer hangs at drain/rinse cycle | Zor | Washer Repair | 1 | 01-26-2009 05:36 AM |
| Squeal on final rinse | gregerr | Washer Repair | 0 | 12-18-2008 10:07 AM |
