Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Bosch Dishwasher outer door re assembly (http://forum.appliancepartspros.com/dishwasher-repair/148222-bosch-dishwasher-outer-door-re-assembly.html)
clubmaker 12-01-2010 01:34 PM
I replaced the control module on my Bosch SHU4306 dishwasher and I am trying to put the door back together. There are 2 parts, the door and the top piece which holds the control module.
Which one should I screw in 1st. The door or the top piece. It seems like I need about 4 hands to accomplish this. Any help is appreciated. Thanks
John
Gene 12-01-2010 03:10 PM
1 Attachment(s)
John,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for Bosch SHU4306 UC/11 (FD 8001-8003) | AppliancePartsPros.com
clubmaker 12-04-2010 02:51 PM
Quote:
Originally Posted by Gene (Post 310272)
John,
Thanks Gene, I got it all back together and thanks to everyone else on the forum explaining the control module replacement.
It was very easy to replace the module, but a little tricky getting the door back on by myself, it would of been easier with two people.
hanginthere 12-09-2010 12:09 PM
used the instructions to locate and repair bad solder connection on control board. Worked like a champ.
I see this has been an issue for a long time. Recall??? board appears overheated by current not cold solder.Bad design??
How many poor bastards don't run across this fix and spend ridiculous $ on the repair. Bosch is supposed to be 1 of the best brands.
JA
pridbor 12-30-2010 11:28 PM
Thermador Dishwasher heater problem(again)
I'm in the process of fixing the red wire soldering on the Control Module, and have seen a reference to a Test Program. Can somebody please shed a little light as to how to invoke this? Thanks in advance Pridbor
