Originally Posted by: Paavo007  Initial symptom on Frigidaire Model gld2250rdq0 dishwasher: any food particles not rinsed off are splattered all over, and soap is also splattered all over undissolved.
Observations: 1 - Top spray arm doesn't appear to be getting sufficient water to rotate it - it does rotate by hand freely and holes are free/unclogged. Even put it on the 'top rack only' setting - bottom rack only sprays - nothing out of the top.. 2 - Found out that this dishwasher is supposed to alternate water supply between the upper and lower spray arms (vs both spraying simultaneously) by way of a check ball in the housing at the bottom below the filters/screens. It appears that this almighty checkball is not changing positions and allowing water to flow to the upper spray arm (explained below..)
Steps taken so far: - A local repairman replaced the following parts: water valve, upper and lower spray arms, motor, recirculation tube (runs water up to the top spray arm), heating element. No change in symptoms - repairman out of options. - verified the drain tube is free/unclogged and draining as expected - verified water temp from faucet is sufficient (140+) - verified water is sufficiently soft - I removed housing that covers checkball - appeared to be clean and moving freely. Re-assembled and tested - no difference. Dissembled again and forced the checkball to stay in the position blocking the bottom spray arm and reassembled to see if the top spray arm was getting water and would spray - it did. Disassembled, returned checkball to 'normal' state, and re-assembled - no improvement in symptoms. - Added an addional couple quarts of water to see if water volume was the issue – no improvement in symptoms.
Questions: 1 - How can I verify if the water valve replaced was bad (rare, but can happen I'm sure..) and/or if the dishwasher is getting enough water to do it's thing? When done filling (fills for 87 seconds, as I'm told is what it's programmed to do), the water level is just above the filter/screen - not even close to the heating element as many sources are indicating it should be.. 2 - Is it possible that the pump and/or checkball are somehow malfunctioning? How could I verify? Do the sypmptoms/observations stated above point more to a bad pump (about the only thing not replaced yet..) or a bad water valve (already replaced once..)?
Any insight/advise would be MUCH appreciated!
Jerry, It sure sounds like you have a water supply problem, the new fill valve should have solved that. You may have to check or replace the water supply line and shut off. You need to supply 1 gallon of water per minute at 20 psi to the fill valve itself, (the Higher psi and GPM, the better) with a 3/8 inch (inside diameter) pipe or fill tube. Another quick check is: Is there a pause between the end of the fill cycle and the motor start. There should be. you have approximately 90 seconds to get 1.2 (1 gal.&1.5 quarts) of water into the tub,to produce the proper pressure inside the pump, if the unit is still filling when the motor starts, then you have a slow fill, and the unit wont wash proper. You should also check the float and float shaft, to make sure it is moving proper and is not partially sticking in the "up" position causing a "short" fill cycle(time). Based on your description of the condition of the internal components in the pump, I doubt if that is your problem, I wouldn't rebuild the pump at this point. I've attached a description of how the pump check ball, and wash arm operation occurs, so you'll have a better idea, and you can see how a poor water fill could affect the operation and washability of the unit. WATER DISTRIBUTION SYSTEM
The water distribution system consists of an upper and lower spray arm, upper (spray) arm delivery tube, filter, soil director, pump, sump, and check ball. The system is designed to operate only one spray arm at a time. During the first wash and first and second rinses, only the lower spray arm operates. In the second wash, third and fourth rinses the spray arms alternate about every 90 seconds. This alternating of the spray arms is achieved with a check ball located on a ramp between two outlets of the pump. There is an outlet to the bottom spray arm and an outlet to the upper arm delivery tube. In the normal position the ball is at the bottom of the ramp, in front of the opening to the upper arm delivery
When the pump starts, the force of the water pushes the ball to block the opening to the upper arm delivery tube.
Not all of the water is blocked however. The opening is constructed to allow a small amount of water to bypass the ball and enter the tube, and fills the tube at a rate of approximately four inches a second. At the same time, the outlet to the lower spray arm is open, so the lower spray arm operates. When the pump stops, the pressure is removed from the ball and the water flows down the tube, forcing the ball up the ramp and against the outlet to the lower spray arm. If the pump remains off for more than 3 seconds, all the water in the tube escapes and the ball returns to the bottom of the ramp. But, if the pump is started in less than .6 seconds, the water from the upper arm delivery tube is still forcing the ball up the ramp against the outlet to the lower spray arm. The force of the water from the pump continues to hold the ball against the outlet to the lower spray arm which leaves the outlet to the upper arm delivery tube open. When the ball is in this position only the upper spray arm operates. This momentary stopping of the pump is controlled by the control board. Another unique feature of the water distribution system is the two cavities of the sump. One cavity provides filtered water to the pump for recirculation through the spray arms. The other, called a quiet water cavity, allows soil to collect in the area of the macerator blade, where it is held until the drain pump removes it.
Good Luck, :) :) :)
