Discuss
Detergent Dispenser
 in
Dishwasher Repair
I have Kitchen Aid Dishwasher KUDI230B0 where the soap dispenser "fan" on the door stays shut and does not open
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Detergent Dispenser
  #1 (permalink)
Old 11-26-2010, 08:30 AM
Junior Member
wrightc is on a distinguished road
Default Detergent Dispenser
Brand: Kitchen Aid   Age: More than 10 years
I have Kitchen Aid Dishwasher KUDI230B0 where the soap dispenser "fan" on the door stays shut and does not open to dispense soap during wash cycle.
Don't know if the dispenser is the problem or a screw or another part is the problem.
Dispenser is discontinued, so I can't order it. Help!
  #2 (permalink)
Old 11-26-2010, 12:30 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
The bi metal switch assembly for the cup is,
Part number: AP3041715
You could remove the dispenser from the door assembly,
Clean and lube the moving parts,
Install the new part.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-26-2010, 04:09 PM
Junior Member
Default
Good Luck,
THANKS!!
Is this something that a Happy Homeowner could do or do I need to call a local company that services Kitchen Aid Dishwashers???
  #4 (permalink)
Old 11-29-2010, 06:55 AM
Senior Expert
Default
THANKS!!
If you've got basic skills and basic hand tools,
You'll be fine.
Just remember, *** turn the POWER OFF*** to the dishwasher before you start.
Remove the inner door liner from the door asembly, carefully.
Disconnect the wires to the detergent cup, label the wires, so you can reattach them to the new switch.
Remove the bi metal switch assembly.
Soak the complete assembly in hot water and dry thoroughly.
You may want to test the door operation,before you install the new switch.
You may also want to put a couple of drops of oil (3in1,is decent)on the shaft and let it migrate down, into the housing.
Install the switch.
Reverse the procedure and test the unit for operation.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 02-20-2011, 01:38 PM
Junior Member
jeffepops is on a distinguished road
Default Bimatal Electrical Issue?
I opened up my door and checked out the electrical circuit -- the blue wire was running power (test lite lit up when grounded), but the yellow/black wire connected to the other side never completed a circuit when I ran thru complete cycle with circuit tester connected. Wires all appear intact and properly connected. Could it still be a problem with the bimetal assmpbly, or is the switch/wiring harness?
  #6 (permalink)
Old 02-21-2011, 08:58 AM
Senior Expert
Default
Quote:
Jeff,
The Blue wire, is the neutral leg of the motor and detergent cup of the bi metal, you were probably reading the voltage from the motor winding.
The Yellow/Black wire is the power to the bi metal from the timer.
Try this,
With a multi meter, check for a resistance reading across the two terminals, with the wires off, on the bi metal switch, on RK1 scale on your meter. You should have a reading, if the switch is good.
Check the yellow / black wire from the detergent cup bi metal to the timer connection, for broken, loose, etc.
Leave the yellow/black wire off the bi metal switch, start the dishwasher at the main wash cycle, approximately 4or5 minutes into the wash cycle there should be 120 VAC on the yellow/black wire, If no voltage you'd have a bad timer or wire.
I'm sure you'll know what to do, and the part needed from there.
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 04-20-2011, 11:31 AM
Junior Member
Default
So, I ordered the new bimetal switch and installed it -- the cup does not open, no voltage to the switch. Should I just replace the timer? The yellow/black and blue wires both look to be in perfect condition. Is it possible the timer works for all the other cycles, but does not send current to bimetal switch? Thanks
  #8 (permalink)
Old 04-20-2011, 01:57 PM
Senior Expert
Default
Jeff,
Yes, it's possible the timer increment could be bad, but that's not a common occurence.
You should have the voltage at the switch for 60 to 90 seconds, and a couple of minutes into the main wash cycle, is that how you tested the circuit and voltage ?
If you're sure the wires are OK, and with the new switch( I wouldn't expect that to be bad) then go with a new timer.
__________________
Joe M. APP TEAM
  #9 (permalink)
Old 04-20-2011, 03:13 PM
Junior Member
Default
Yes, I ran the normal wash cycle. I don't have a multimeter, but I did clip a simple 120/240v circuit tester to the yellow/black and blue leads. It did not light up at all over the first 5 minutes of the normal cycle, and when plugged into the switch, the switch did not open. I had the panel off of the door, so was able to observe that nothing moved anywhere. I ran it several times to be certain. Can't think of what else I should have done. Thanks!
  #10 (permalink)
Old 04-21-2011, 06:43 AM
Senior Expert
Default
Jeff, based on that, I would have to think you do have a bad timer,
Part number: AP2920568
Were it me, I would attach a 120 VAC test cord to the terminals of the bimetal switch, plug it into an outlet and make sure the bi metal switch worps and releases the dispenser door, first.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
detergent dispenser won't work... pallengsp Dishwasher Repair 0 08-26-2009 05:58 PM
Detergent dispenser KenG Dishwasher Repair 0 04-08-2009 10:47 AM
how to replace the detergent dispenser skringel Oven Repair (including Ranges and Cooktops) 1 01-22-2009 06:03 PM
Dispenser Opens but detergent is still in the dispenser biglarry0 Washer Repair 4 02-29-2008 11:22 AM
Detergent dispenser mikewhitetx Dishwasher Repair 1 08-10-2007 09:20 PM
