Discuss
Detergent Dispenser
 in
Dishwasher Repair
Thanks. I will do just that! Jeffrey
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Detergent Dispenser
  #11 (permalink)
Old 04-21-2011, 10:17 AM
Junior Member
jeffepops is on a distinguished road
Default
Jeffrey
  #12 (permalink)
Old 04-21-2011, 11:31 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Jeffrey
Jeffrey,
Good Deal,
When you're done let us know how things went.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 04-26-2011, 03:07 PM
Junior Member
Default
Okay, I am totally confused.... Ran the test and when I plugged in, the switch worked! So, problem is timer or wiring. Clamped one voltage tester lead to yellow/black wire and other one to the green ground wire. Ran dishwasher. Light came on at beginning of normal cycle -- so timer did send voltage to bimetal switch -- but switch did not open (and in several subsequent tries). I pulled the wiring harness from the timer, put it back. On second hookup of tester (one lead to yellow/black, other to ground wire), the circuit breaker popped. Took off leads, reset breaker and... now the switch is working!!! For how long, I do not know. Maybe some loose wiring...Go figure.
  #14 (permalink)
Old 04-27-2011, 06:08 AM
Senior Expert
Default
Jeff,
That happens, sometimes,
Makes you wander ????
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
detergent dispenser won't work... pallengsp Dishwasher Repair 0 08-26-2009 05:58 PM
Detergent dispenser KenG Dishwasher Repair 0 04-08-2009 10:47 AM
how to replace the detergent dispenser skringel Oven Repair (including Ranges and Cooktops) 1 01-22-2009 06:03 PM
Dispenser Opens but detergent is still in the dispenser biglarry0 Washer Repair 4 02-29-2008 11:22 AM
Detergent dispenser mikewhitetx Dishwasher Repair 1 08-10-2007 09:20 PM
