Discuss
Tips on installing new dishwasher motor
 in
Dishwasher Repair
I ordered a new motor for the dishwasher (tech said it was bad), and after pulling the old one out,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Tips on installing new dishwasher motor
  #1 (permalink)
Old 11-13-2008, 08:51 AM
Junior Member
Don73 is on a distinguished road
Default Tips on installing new dishwasher motor
Brand: Kitchen Aid   Age: 1 - 5 years
I ordered a new motor for the dishwasher (tech said it was bad), and after pulling the old one out, I installed the new one. I then started it, and there was water leaking out from the motor area. Is there any tips on how to install the motor correctly? When I pulled the new motor back out, it looked like the seal (rubber gasket on the motor) was not properly in place. Any advice would be greatly appreciated.
  #2 (permalink)
Old 11-13-2008, 10:32 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Apply a thin coat of silicon grease to the o-ring or some dishwashing det. so it slides in easier make sure the motor catches on all the tabs when twisting it on
__________________
  #3 (permalink)
Old 11-13-2008, 10:57 AM
Junior Member
Default
Thank you! The plastic housing has two tabs, while the motor looks like it has space for four tabs. Normal? When I installed it before, the two tabs were connected, and there was a 1/4 inch gap where the bolt went in. After the bolt was tightened down, the gap went away. Just want to make sure I'm doing this the right way.
  #4 (permalink)
Old 11-13-2008, 11:05 AM
Senior Expert
APP Volunteer
Default
There should be 2 tabs in front and one on the left side in rear then the bolt
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tips for moving built-in dishwasher wanted rusbet Dishwasher Repair 2 04-21-2009 05:12 AM
dishwasher repair tips for a dummy caliche1234 Dishwasher Repair 4 03-12-2009 07:46 PM
installing 2188869 motor twapplegate@yahoo.com Refrigerator & Freezer Repair 3 02-13-2009 02:08 PM
installing spring motor pivot misterfixall Washer Repair 0 01-06-2009 01:19 PM
installing new upper rack on dishwasher elisabeth jones Dishwasher Repair 0 01-24-2008 10:07 AM
