69w-30
#1 Posted : Monday, November 10, 2008 5:17:26 PM(UTC)
69w-30
Hi folks, Sorry if this has been answered before, but I didnt find exactly what i'm after.
I recently bought a used KUDI01ILBL1 Undercounter Dishwasher, and installed everything but the heating element doesnt get hot, I havnt taken the element out yet to check it because what ive read you need to replace it if you do remove it.
Is there something else that could be wrong that i could check? The unit seems to cycle and wash fine.
It does have the stainless tub, so I know what part and controller to order if i need to, I just wanted to check first before i ordered it.
P.S. Is the dishwasher suposed to be hooked up to the hot supply or the cold?
I was going to hook it up to the hot but someone i work with said to hook it to the cold???
Thanks in advance for any help : )
Dan
abadfish66
#2 Posted : Monday, November 10, 2008 6:24:18 PM(UTC)
abadfish66
Definatly hook it up to the hot water. You'll never get clean dishes, let alone dry ones using cold water...How do you know the heating element doesn't get hot. It's probably so cold in the dishwasher that your not noticing it working. Hook up to hot water and try again.
69w-30
#3 Posted : Tuesday, November 11, 2008 12:17:49 AM(UTC)
69w-30
Thank you, i will do that when I get home from work today.
#4 Posted : Tuesday, November 11, 2008 12:47:47 AM(UTC)
Check your heater connections under the dishwasher. Put it in heated wash and check for the heater to get hot. If not, you may need a thermistor mounted on the bottom of the tub, part # AP3039201, a small,round device. If you have a meter, you can check the control module for voltage to the heater.
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
How do I test the heating element? (Dryer Repair)
by Jeff Winholt 8/28/2014 3:28:45 PM(UTC)
video testing DW heating element? (Dishwasher Repair)
by jude2014 2/9/2014 6:50:53 AM(UTC)
Dishwasher not drying - high-limit/temp thermostat or heating element? (Dishwasher Repair)
by tom_in_atl 1/20/2014 7:44:08 AM(UTC)
old GE Triton XL: easy to replace heating element?? (Dishwasher Repair)
by Paul_illinois 12/28/2012 10:06:53 AM(UTC)
LG DW with Thermistor error -- Do I have to replace Heating element? (Dishwasher Repair)
by speedyox 11/29/2011 6:16:23 PM(UTC)
How to remove glass top from stove to replace heating element? (Oven Repair (including Ranges and Cooktops))
by swatt1234 1/29/2011 10:38:14 AM(UTC)
How to replace oven heating element? (Oven Repair (including Ranges and Cooktops))
by ssananikone 1/7/2011 7:49:00 PM(UTC)
amana nde8805ayw - how do I get to the heating element? (Dryer Repair)
by andras 3/6/2010 9:28:04 AM(UTC)
bad heating element? (Dryer Repair)
by 6780977 3/1/2010 5:40:58 PM(UTC)
How do I get to the heating element? (Oven Repair (including Ranges and Cooktops))
by Connie49 12/16/2009 4:08:32 PM(UTC)
where is the heating element?? (Dryer Repair)
by GaryChicago1957 8/25/2009 5:10:01 PM(UTC)
where's the heating element? (Oven Repair (including Ranges and Cooktops))
by Warren H 4/11/2009 10:31:58 AM(UTC)
How do I take remove strainer/ Clean heating element? (Dishwasher Repair)
by dishpanhands 10/13/2008 6:33:18 PM(UTC)
