Donw
#1 Posted : Monday, November 10, 2008 1:51:00 PM(UTC)
Donw
We have a problem with our dishwasher starting.....
When I press the "Cycle" select switch (e.g. Normal Wash, Risnse, etc.) on the display panel, the countdown display flashes as it's suppose to. However, when I press the "Start/Cancel" button immediately after, nothing happens....the machine doesn't start....The display keeps flashing and then "times-out" after 30 seconds (as it's suppose to)...
I recently replaced the door latch mechanism but cannot see where that has anything to do with the machine not starting as the door seems to latch properly.
The circuit breaker has been checked and seems to be ok as there is A/C power to the machine. Could I have a faulty start switch? Can it be replaced or is it part of the control board assembly?
#2 Posted : Monday, November 10, 2008 8:38:18 PM(UTC)
The first thing I would do is check the door switches and see if they properly engaged with the door closed.
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
Maytag Dishwasher Won't Start... (Dishwasher Repair)
by jd122653 11/8/2013 1:29:47 PM(UTC)
Maytag Dishwasher won't start (Dishwasher Repair)
by tommies1 10/30/2013 10:03:58 PM(UTC)
Maytag dishwasher won't start (Dishwasher Repair)
by WMCCOX 11/1/2012 3:42:59 PM(UTC)
by jd122653 5/4/2012 9:59:03 AM(UTC)
by gunner_1911 9/26/2011 2:20:00 PM(UTC)
by k5wls 7/4/2011 8:01:19 PM(UTC)
by caroltdds 6/3/2011 9:07:05 AM(UTC)
maytag dishwasher won't start (Dishwasher Repair)
by cozzy 4/27/2011 1:21:50 PM(UTC)
by griz369 2/15/2011 1:19:09 PM(UTC)
Maytag Dishwasher Won't Start (Dishwasher Repair)
by hmanka 8/25/2010 5:12:13 AM(UTC)
by Whatnow? 4/15/2008 4:53:13 PM(UTC)
