| » dishwasher leaking on the bottom |
Model Number: gldb656jb0 Brand: Frigidaire Age: 5 - 10 years
help i an trying to fix the leak. ok took dishwasher out found leak i thought. look like it is comming from front of motor so i took it out ,there was a thick rubber called a mount-motorfront so i replaced it still leaks plus i don't think the spray arm is working, is that controlled by the motor and the pump assembly, plus the motor was hot
If your washer fills up to near the heater, the pump should spray up the water.
If not, drain dishwasher and remove spray arm housing and pull the half round cover that covers the pump impeller. Suck up any water there, turn water off the unit and turn on in wash mode. Check the rotation direction of the motor, if turning the wrong way, you will need to replace the motor pump assembly. They have had a lot of problems with this sidewinder motor reversing direction Your motor part # is AP3160640 cost $136.87
__________________
| Display Modes | |
| Leaking dishwasher door | flowboard | Dishwasher Repair | 1 | 10-03-2007 09:52 PM |
| dishwasher leaking at bottom of door | skinnybeak | Dishwasher Repair | 0 | 09-24-2007 06:22 PM |
| ice build up in the bottom of the freezer | lauder | Refrigerator & Freezer Repair | 1 | 08-22-2007 08:53 PM |
| Maytag Washer Bottom of tub leaking at seal | David S | Washer Repair | 4 | 08-11-2007 12:16 AM |
| humming coming from the bottom of system | ahchitski | Dishwasher Repair | 1 | 07-23-2007 04:03 PM |
