| » Older GE Dishwasher, new timer, no V to drain solenoid |
Model Number: GSD640G-02 Brand: GE Age: More than 10 years
Drain solenoid burned up because it stuck on,
likely due to the burned contacts in the timer. Replaced the drain solenoid and the timer. Both with new parts, timer is GE oem part. Ran it thru a cycle, noted it wasn't draining because the drain solenoid wasn't opening. Scooped most of the water out, disconnected the wires to the drain solenoid and hooked them up to my multi-meter (verified good in a wall receptacle). Ran it thru another cycle, at no time did the drain solenoid get 110 volts. Had bought the washer used, the manual that is supposed to be under the right side of the tub is missing, so I don't have a wiring diagram to check to see if the 3 wire cycling switch has anything to do with the drain solenoid. On that switch, 1 wire is a neutral, 1 comes from the timer motor (neutral side of the motor) and there's another hot wire. None of the wire colors on the cycling switch are the same color as the hot wire to the drain solenoid, but that doesn't necessarily mean anything. Appreciate any help or ideas. Also - Had the float valve out and checked for continuity, is OK, but when running thru a cycle when it wasn't draining, the tub overfilled - ? Haven't checked the float yet, maybe sticking? Ads By Google Related Models |
| Display Modes | |
| Drain Solenoid Keeps Melting | valky | Dishwasher Repair | 4 | 05-16-2009 11:24 AM |
| Maytag dishwasher drain solenoid problem | cajunater | Dishwasher Repair | 2 | 05-16-2009 10:47 AM |
| Hotpoint Dishwasher HDA750S-45BA Drain Solenoid | tjones829 | Dishwasher Repair | 3 | 04-21-2009 06:31 AM |
| Older KitchenAid Timer? | 708Outer | Dishwasher Repair | 2 | 01-01-2009 10:30 AM |
| Drain Solenoid Burns Out | wow | Dishwasher Repair | 3 | 04-28-2008 02:23 PM |
