When washing the dishes yesterday I opened the front door quickly to see if the top spray arm located just under the top rack was spinning and shooting up water. I noticed the lower spray arm below the bottom rack was still slowly spinning and coming to a stop when the door was opened, but the top one had not moved. The setting for the wash was on normal wash, not pots and pans setting. Does anybody know if the setting matters regarding the top spray arm moving? If it is supposed to always spin and shoot up water to the top rack, what would make it not work? Thx, Mark
Read more: http://forum.appliancepartspros...post302359#ixzz15TIqOAbT http://forum.appliancepartspros.com
