Discuss
Dishwasher is leaking water around motor
 in
Dishwasher Repair
I have a KitchenAid dishwasher that is leaving a puddle of water on the floor. I removed the motor cover
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher is leaking water around motor
  #1 (permalink)
Old 11-07-2008, 08:56 AM
davesob davesob is offline
Junior Member
davesob is on a distinguished road
Default Dishwasher is leaking water around motor
Model Number: KUDM24SEBL1   Brand: Kitchen Aid   Age: 5 - 10 years
I have a KitchenAid dishwasher that is leaving a puddle of water on the floor. I removed the motor cover and noticed that it is leaking around the motor and there is some soap corrosion around the housing. I think the pump/motor gasket needs replacing. Is this gasket removed from inside the washer or does the pump/motor need to be removed from the bottom?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-07-2008, 09:43 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
It comes apart from the inside you need an impellar seal kit comes with wash/drain impellars chopper blade, pump seal and a couple o-rings. if you want to replace the whole pump assy then you release the tabs and push it up to the inside
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dishwasher won't drain and is leaking water SHS1988 Dishwasher Repair 3 11-03-2008 01:05 PM
Kenmore dishwasher motor won't pump water out astro3ron Dishwasher Repair 2 03-04-2008 08:24 PM
Dishwasher leaking while off jwcyre Dishwasher Repair 2 02-28-2008 01:44 PM
Dishwasher leaking Jet Dry rob g Dishwasher Repair 0 01-26-2008 03:48 PM
Dishwasher leaking jeremiah Dishwasher Repair 3 11-14-2007 12:02 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
