| » Dishwasher just beeps, no display, will not start |
Model Number: SHE98M05UC/49 Brand: Bosch Age: 1 - 5 years
My SHE98 stopped working, when you try to turn the unit on to select a cylce it beeps but the displays (both the one on top of and on the front of door) do not light up. We cannot choose a cycle or start the unit.
I turned power off to the unit and re-applied it to see if that would reset anything but no change. I then assumed it must be a problem with either a button or the control unit (both in the same module) so I replaced the door mounted control unit. No luck. There is a second control unit in the base but I really need help before I try any other parts. Has anyone else seen this problem or have a troubleshooting chart? Thanks Ads By Google Related Models |
I've had the same problem for a few months now. comes and goes. mostly comes. I had a technician here. he replaced 2 electronic components in the front but that did not solve the problem. although it did go away for about 2 months. now its back again. I'm going to try to fix it myself this time. ordering a control unit mounted in the bottom back of the unit. part number 666091.
I have the exact same issue with a Bosch SHX98M09UC
Were you guys ever able to get it working? I found if I shut off the breaker for 30 seconds, I can get it to do one cycle, then it does the same thing. (Beep with no light) |
I had the exact same problem. Opened the front and took out the control board, yes took it out of the 666092 box and tried to order the part, looks like you cannot only order the board.
Then I found this thread and decided to not order 666092, put everything back together and it now works without replacing any parts. I assume it will die eventually again. How do I get to 666091 control unit? Do I take off the right side panel? How? Schor |
| Display Modes | |
| Has power, will not start (just beeps) | lbe86 | Dryer Repair | 0 | 10-10-2010 02:36 PM |
| Whirlpool Double Oven No Display but beeps | DIY Fireman | Oven Repair (including Ranges and Cooktops) | 3 | 03-26-2010 07:36 PM |
| whirlpool double oven, only beeps, no display, does not turn on | umairs123 | Oven Repair (including Ranges and Cooktops) | 0 | 02-15-2010 07:17 AM |
| Display panel comes on and off and beeps and stays off | miadave | Oven Repair (including Ranges and Cooktops) | 5 | 10-18-2009 09:05 AM |
| lost digital display, beeps when pressing buttons | lapulapu | Oven Repair (including Ranges and Cooktops) | 2 | 10-04-2009 09:03 PM |
