Discuss
Bosch dishwasher won't fill
 in
Dishwasher Repair
First noticed that it did not clean, and soap did not dissolve. Ran another cycle and found little or no
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher won't fill
  #1 (permalink)
Old 11-04-2008, 07:13 PM
Junior Member
bunkytadwell is on a distinguished road
Default Bosch dishwasher won't fill
Model Number: smu4052UC/14   Brand: Bosch   Age: 5 - 10 years
First noticed that it did not clean, and soap did not dissolve. Ran another cycle and found little or no water in the unit when it was supposed to be washing.
I added a couple of pitchers of water and it worked OK. The water supply is OK.
I think the problem is one of the below:
water input filter
timer
imput valve
water level control
I cannot find anything that looks like a water level sensor, and the part list on this web site does not show one....??
I have not taken it apart except for some trim pieces for inspection. Before I do take anything apart, do any of the experts here have any suggestions??
Any help or suggestions would be appreciated.
thanks in advance.
bunky
Ads By Google
Related Models
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
Maytag SMV9165BC Mwave - Mounted Over Range/wo
Maytag SMV9165CC Mwave - Mounted Over Range/wo
Maytag SMV9165SC Mwave - Mounted Over Range/wo
Maytag SMV9165WC Mwave - Mounted Over Range/wo
Thermador SMW272B
Thermador SMW272P
Thermador SMW272S
Thermador SMW272W
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Whirlpool SN
Amana SNAC-700.A Commercial Microwaves
Amana SNAC-700.B Commercial Microwaves
Amana SNAC-7TP.A Commercial Microwaves
Amana SNAC-7TP.B Commercial Microwaves
Amana SNAC700 Commercial Microwaves
Amana SNAC700.C Commercial Microwaves
Amana SNAC700.D Commercial Microwaves
Amana SNAC7TP.003 Commercial Microwaves
Amana SNAC7TP.004 Commercial Microwaves
Amana SNAC7TP.005 Commercial Microwaves
Amana SNAC8LW Commercial Microwaves
Amana SNE26AA Range - Electric Std Delaware
Amana SNE26CB Range - S/c S/i Ddraft Gas
Amana SNE26ZZ Range - S/c S/i Ddraft Gas
Whirlpool SNFGA
Amana SNK26AA Range - S/c S/i Ddraft Gas
Amana SNK26AA0 Range - S/i Std Gas
Amana SNK26AA5 Range - S/i Std Gas
Amana SNK26CB Range - S/c S/i Ddraft Gas
Amana SNK26CB0 Range - S/i Std Gas
Amana SNK26CB5 Range - S/i Std Gas
Amana SNK26FS Range - S/c S/i Ddraft Gas
Amana SNK26FS0 Range - S/i Std Gas
Amana SNK26FS5 Range - S/i Std Gas
Amana SNP26AA Range - S/i Std Gas
Amana SNP26AA0 Range - S/i Std Gas
Amana SNP26AA5 Range - S/i Std Gas
Amana SNP26AH0 Range - S/i Std Gas
Amana SNP26CB Range - S/i Std Gas
Amana SNP26CB0 Range - S/i Std Gas
Amana SNP26CB5 Range - S/i Std Gas
Amana SNP26ZZ Range - S/i Std Gas
Amana SNP26ZZ0 Range - S/i Std Gas
Whirlpool SNPA
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A Ref - SXS/I&W
Amana SP17A-A Ref - SXS/I&W
Amana SP17A-AG Ref - SXS/I&W
Amana SP17A-C Ref - SXS/I&W
Amana SP17G Ref - SXS/I&W
  #2 (permalink)
Old 11-05-2008, 10:56 AM
Junior Member
Default
After taking the bottom covers off it appears that the water switch solenoid is open.
At least there is no continuity across the terminals of the valve.
I am still a little puzzled as to how the diswasher "knows" that it has enough water in it.
Other dishwashers I've owned always had a float that would activate when the water was full, but this one doesn't seem to have one...
  #3 (permalink)
Old 11-07-2008, 02:04 PM
Junior Member
Default
For anyone that is iterested -- the water level sensor appears to be part of the water valve.
There is a second, smaller tube coming off of the valve and it appears that this is a water level feedback tube which will shut the valve off if there is too much water in the tub.
OR -- as in my case...
The water level feedback circuit was clogged somehow and the valve "thought" that the tub was overfull at all times, not allowing water to flow into the tub.
At first I thought the valve solenoid was open, but that was not the case.
A new valve fixed the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher will not fill gundogofct Dishwasher Repair 5 09-02-2012 03:26 PM
Bosch Dishwasher Will Not fill with water drskinner Dishwasher Repair 1 10-06-2009 09:35 AM
bosch dishwasher will not fill water loas Dishwasher Repair 1 10-06-2009 09:31 AM
Bosch SHU 43C dishwasher won't fill Panther Dishwasher Repair 2 09-23-2008 12:03 PM
Bosch dishwasher won't fill KimB Dishwasher Repair 1 06-05-2008 07:27 PM
