| » no power to the controls on the door |
Model Number: mdb915oawq Brand: Maytag Age: More than 10 years
I am unable to press any control buttons on the door because there seems to be no power to the lights or controls. I have already tried to change the door latch and handle which did not work. Can you give me some indication what the problem may be and the part I may need to solve the problem. Appreciate your help.
You can get a good meter (not really expensive, and useful to have around the house) at your local home builders' store, or electronics store. It doesn/t need to be fancy...All you really need is the abilith to check for electricity (voltages up to 240VAC; resistance (and continuity). I would start by checking the electrical connections to the dishwasher (under the tub, behind the toe panel. Check for 120VAC; AND for good secure connections. If the incoming power is good, next check the integrity and continuity of te door switches.
Bear in mind that there is no shame in not feeling comfortable with electrical testing. If you rather call in a pro just for the diagnosis, you can still save a bunch of money by doing the labor yourself. Let us know what you find. |
| Display Modes | |
| Maytage All power to Controls Is out | 676BACK | Washer Repair | 1 | 09-04-2010 06:02 PM |
| No power after self clean; door locked | mulean | Oven Repair (including Ranges and Cooktops) | 12 | 07-20-2010 04:16 PM |
| JennAir Refrig Door Controls - Ice Dispenser Door Solenoid Valve | kwlex | Refrigerator & Freezer Repair | 0 | 12-07-2009 01:09 PM |
| power controls | balls52 | Dryer Repair | 1 | 06-03-2009 05:55 PM |
| oven controls don't work after power outage | nooven | Oven Repair (including Ranges and Cooktops) | 1 | 12-07-2008 02:08 PM |
