Hi, I have a Kenmore Coldspot model 106.56666500. It started to occasionally make a loud vibrating noise when dispensing water. The noise would stop and then the dispenser would work. Just recently, after the loud noise, the water dispenser stopped working. No noise, no water. I suspect the water inlet valve. Do you think this is the problem, and if so, is it a difficult fix? Thanks!
Very likely the problem is a bad water inlet valve. It comes with the installation instructions. - The water inlet valve Part number: AP3160649
