Discuss
Dishwasher leaking water from motor area
 in
Dishwasher Repair
I have a Kenmore Dishwasher that leaks water when run. It seems to run perfectly but leaks water. I suspect
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher leaking water from motor area
  #1 (permalink)
Old 11-03-2010, 10:25 PM
Junior Member
thenefas is on a distinguished road
Default Dishwasher leaking water from motor area
Model Number: 363.1414599   Brand: Kenmore   Age: More than 10 years
I have a Kenmore Dishwasher that leaks water when run. It seems to run perfectly but leaks water. I suspect it's due to having not run at all for 8 months while we weren't living in the house. Other than the leak, it runs perfectly. The water is dripping from the bottom of the motor so I suspect, (correct me if I'm wrong), it's the impeller shaft seal. Can I replace this seal and carry on or will it require more than that?
Also, is there a write-up anyone knows about to accomplish that task?
TIA
Brian
Related Models
Kenmore 3631401190 DISHWASHER
Kenmore 3631401191 DISHWASHER
Kenmore 3631401590 DISHWASHER
Kenmore 3631401591 DISHWASHER
Kenmore 3631401592 DISHWASHER
Kenmore 3631401890 DISHWASHER
Kenmore 3631401891 DISHWASHER
Kenmore 3631401892 DISHWASHER
Kenmore 3631402190 DISHWASHER
Kenmore 3631402191 KENMORE DISHWASHER
Kenmore 3631402192 DISHWASHER
Kenmore 3631402590 DISHWASHER
Kenmore 3631402591 DISHWASHER
Kenmore 3631402592 DISHWASHER
Kenmore 3631402890 DISHWASHER
Kenmore 3631402891 KENMORE DISHWASHER
Kenmore 3631402892 DISHWASHER
Kenmore 36314031000 DISHWASHER
Kenmore 36314031001 DISHWASHER
Kenmore 36314032000 DISHWASHER
Kenmore 36314032001 DISHWASHER
Kenmore 36314038000 DISHWASHER
Kenmore 36314038001 DISHWASHER
Kenmore 36314039000 DISHWASHER
Kenmore 36314039001 DISHWASHER
Kenmore 3631404193 DISHWASHER
Kenmore 3631404194 DISHWASHER
Kenmore 3631404196 DISHWASHER
Kenmore 3631404197 DISHWASHER
Kenmore 3631404593 DISHWASHER
Kenmore 3631404594 DISHWASHER
Kenmore 3631404595 DISHWASHER
Kenmore 3631404596 DISHWASHER
Kenmore 3631404597 DISHWASHER
Kenmore 3631404893 DISHWASHER
Kenmore 3631404894 DISHWASHER
Kenmore 3631404895 DISHWASHER
Kenmore 3631404896 DISHWASHER
Kenmore 3631404897 DISHWASHER
Kenmore 36314051690 DISHWASHER
Kenmore 36314051691 DISHWASHER
Kenmore 36314061790 AUTOMATIC DISHWASHER
Kenmore 36314061791 DISHWASHER
Kenmore 36314071790 AUTOMATIC DISHWASHER
Kenmore 36314071791 DISHWASHER
Kenmore 36314071792 DISHWASHER
Kenmore 36314071793 DISHWASHER
Kenmore 36314071794 DISHWASHER
Kenmore 36314072790 AUTOMATIC DISHWASHER
Kenmore 36314072791 DISHWASHER
Kenmore 36314072792 DISHWASHER
Kenmore 36314072793 DISHWASHER
Kenmore 36314072794 DISHWASHER
Kenmore 36314072795 DISHWASHER
Kenmore 36314074790 AUTOMATIC DISHWASHER
Kenmore 36314074791 DISHWASHER
Kenmore 36314074792 DISHWASHER
Kenmore 36314074793 DISHWASHER
Kenmore 36314074794 DISHWASHER
Kenmore 36314075790 AUTOMATIC DISHWASHER
Kenmore 36314075791 DISHWASHER
Kenmore 36314075792 DISHWASHER
Kenmore 36314075793 DISHWASHER
Kenmore 36314075794 DISHWASHER
Kenmore 36314081990 DISHWASHER
General Electric 36314081991 DISHWASHER
Kenmore 36314081992 DISHWASHER
Kenmore 36314081993 DISHWASHER
Kenmore 36314081994 DISHWASHER
Kenmore 3631410690 DISHWASHER
Kenmore 3631410691 DISHWASHER
Kenmore 3631410692 DISHWASHER
Kenmore 3631410693 DISHWASHER
Kenmore 3631410694 DISHWASHER
Kenmore 3631411690 DISHWASHER
Kenmore 3631411691 KENMORE DISHWASHER
Kenmore 3631411692 DISHWASHER
Kenmore 36314141690 DISHWASHER
Kenmore 3631414593 DISHWASHER
Kenmore 3631414594 DISHWASHER
Kenmore 3631414595 DISHWASHER
Kenmore 3631414596 DISHWASHER
Kenmore 3631414597 DISHWASHER
Kenmore 3631414598 DISHWASHER
Kenmore 3631414691 DISHWASHER
Kenmore 36314151000 DISHWASHER
Kenmore 36314152000 DISHWASHER
Kenmore 36314158000 DISHWASHER
Kenmore 36314159000 DISHWASHER
Kenmore 36314171790 AUTOMATIC DISHWASHER
Kenmore 36314171791 DISHWASHER
Kenmore 36314171792 DISHWASHER
Kenmore 36314172790 AUTOMATIC DISHWASHER
Kenmore 36314172791 DISHWASHER
Kenmore 36314172792 DISHWASHER
Kenmore 36314174790 AUTOMATIC DISHWASHER
Kenmore 36314174791 DISHWASHER
Kenmore 36314175790 AUTOMATIC DISHWASHER
Kenmore 36314175791 DISHWASHER
Kenmore 36314181200 DISHWASHER
Kenmore 36314181202 DISHWASHER
Kenmore 36314191990 DISHWASHER
Kenmore 36314191991 DISHWASHER
Kenmore 36314191992 DISHWASHER
Kenmore 36314191993 DISHWASHER
Kenmore 36314192990 DISHWASHER
Kenmore 36314192991 DISHWASHER
Kenmore 36314192992 DISHWASHER
Kenmore 36314192993 DISHWASHER
Kenmore 36314194990 DISHWASHER
Kenmore 36314194991 DISHWASHER
Kenmore 36314194992 DISHWASHER
Kenmore 36314194993 DISHWASHER
Kenmore 36314195990 DISHWASHER
Kenmore 36314195991 DISHWASHER
Kenmore 36314195992 DISHWASHER
Kenmore 36314195993 DISHWASHER
Kenmore 36314231100 DISHWASHER
Kenmore 36314232100 DISHWASHER
Kenmore 36314234100 DISHWASHER
  #2 (permalink)
Old 11-04-2010, 07:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find 363.1414599, the following is for a 363.1414598.
Replacement parts for KENMORE 3631414598 | AppliancePartsPros.com
Would be best to check with AppliancePartsPros to make sure yours is the same.
There is a seal kit part way down the page. If you click on the picture a new page will open with more views and then you can click on them to expand them.
Basically a picture is worth a thousand words.
Looks like instructions are included.
Here is a good link with GE info
http://www.applianceaid.com/ge-dish.html
If I cross match WD19X10032 (#6 item in the above link), it comes back with the same number as the kit shown is the ApplancePartsPros link.
Cannot say but if it is the motor/pump seal this should fix it.
NOTE: Be sure to add a couple quarts of water to the unit before firing it up. These pumps do not like to run when dry, they can burn up the pump seal.
See above.
Also a turkey baster or sponge comes in handy to get most of the water out of the unit before disconnecting. Saves on mopping up a mess. Remove the sump cover to get at it. Be careful as there is often broken glass in the sump.
__________________
  #3 (permalink)
Old 11-04-2010, 07:55 AM
Junior Member
Default
Thanks denman, I'm going to check it out. Maybe I can find a number on the motor that will verify which part I need.
The dishwasher came with the house, which we built, so maybe the model number is a contractor thing, idk.
Thank you and I'll post results.
Brian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Leaking From Motor Area BRONCOMAN58 Dishwasher Repair 2 10-05-2010 06:19 AM
GE washer leaking under the agitator area handyman Glenn Washer Repair 3 08-26-2010 03:55 PM
Dishwasher Leaking Water jlehn Dishwasher Repair 2 06-26-2009 10:56 AM
Dishwasher is leaking water around motor davesob Dishwasher Repair 1 11-07-2008 09:43 AM
Leak from motor area esmyth Dishwasher Repair 5 12-07-2007 07:07 AM
