Discuss
Jerky, Noisey, Slow Spin
 in
Dishwasher Repair
Please disregard this posting, it's in the incorrect forum. Thomas Jefferson once said "When you reach the end of your
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Jerky, Noisey, Slow Spin
  #1 (permalink)
Old 11-03-2010, 07:03 PM
Junior Member
nhguy261 is on a distinguished road
Default Jerky, Noisey, Slow Spin
Model Number: LSQ8243HZ0   Brand: Whirlpool   Age: 5 - 10 years
Thomas Jefferson once said "When you reach the end of your rope, tie a knot in it and hang on." Well, right now, I'm hanging onto that knot with my teeth. Here's my pathetic story...
About 10 days ago the Whirlpool top loading, direct drive washer starting acting up. It fills, agitates and drains with no problem but as it's draining and the spin cycle starts it makes a loud intermittent noise and the spin basket has a slow jerking motion. The spin speed never gets any faster. The noise is as if something is "trying" to prevent the spin basket from spinning but can't stop the spin completely.
So far I've inspected the coupler, all components are fine. They were replaced a year ago. Additional research pointed to the clutch so I replaced it. I'm sure the machine appreciates the new part but the problem persists. More research led me to richappy's sticky Replacing direct drive washer brake shoes, a fine piece of useful literature. I purchased the spanner wrench and successfully removed the drive block nut, spin basket and drive block. All three components have been thoroughly cleaned and inspected. They're beautiful. Also, there's nothing obstructing the spin basket.
I moved on to the brake assembly. I disassembled and inspected all of the components but, be warned, this is where my questions begin.
  1. The sticky says: "To repair the old shoes, I routinely grind down the shoe pads by 1/8 inch or less..." The shoes I removed have worn evenly and are about 1/8" thick, how much have they worn if they are currently an 1/8" thick? Should I grind the shoes at all? It sounds like my brake shoes are too thin if I should be able to grind off an 1/8". The brake housing has no rust and is not pitted at all.
  2. Assuming I can re-use the old shoes, the sticky says: "...I put oil on the brake shoe pads..." What kind of oil do I put on the shoes?
  3. The rollers look good and they roll freely. Can I use silicone spray or is silicone grease recommended?
  4. While doing all the above, and more, I gave the spin tube a spin just for the heck of it and to my surprise , I was able to replicate the same sound the machine was making without my assistance. Keep in mind that I've followed the sticky to the letter and didn't tighten the drive block nut which means that when I gave the spin tube a little ride, it was spinning against the drive block. Is it possible that my spin cycle problem, and noise, are due to a bad drive block?
  5. So, if it's not the coupling, and it's not the clutch, and it's not the brakes, and it's not the drive block, is it the tranny? The guy who sold me the spanner wrench voted for the tranny but I don't have a lot of faith in him because he didn't know that the machine had brakes and considered the clutch and brakes to be one in the same.
A few more things:
  1. I appreciate you taking the time to read my posting, thank you.
  2. I'll appreciate it even more if you reply with some good advice...related to my posting.
  3. Remember, I'm still hanging onto that rope with my teeth and I can smell the delicious pie my wife is baking. Hint, hint: I love pie.
Seriously, thank you for your time.
Ken
Ads By Google
Related Models
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Last edited by nhguy261 : 11-04-2010 at 06:42 AM. Reason: Posted to Incorrect Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisey dryer slow to dry Don OBrian Dryer Repair 3 05-08-2011 10:14 AM
slow spin savoy Washer Repair 1 04-21-2010 06:58 AM
slow to no spin JeffPaul Washer Repair 1 01-27-2010 11:36 AM
Noisey spin cycle butch45 Washer Repair 3 01-13-2010 07:54 AM
slow spin herman Dishwasher Repair 0 05-03-2008 12:13 PM
