| » Getting to the drain pump |
Model Number: DU943PWK00 Brand: Whirlpool Age: 1 - 5 years
My dishwasher is not draining so I started taking some of it apart. Could not figure out how to undo the hex nut black thing just would spin. Do i need to hold it still with a one inch wrench while turnin the hex nut? I think it is clogged under there somewhere?.
The first thing I would check is the check valve (#15 on the break down diagram). Remove the drain hose from the check valve and unscrew it from the pump. Most likely there is a foreign object stuck inside.
Here are the break down diagrams for the Whirlpool dishwasher Model DU943PWKT0 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
| New pump but washer will still not drain | FredPam | Washer Repair | 5 | 08-29-2009 04:01 PM |
| Drain Pump issues | netmndr35 | Dishwasher Repair | 1 | 06-02-2009 10:41 AM |
| will this pump also pump the drain water out | Paul Radovsky | Dishwasher Repair | 5 | 07-20-2008 01:41 PM |
| Drain Pump | loadster | Dishwasher Repair | 1 | 08-07-2007 06:35 PM |
