Discuss
Bosch Dishwasher On/Off Switch
 in
Dishwasher Repair
The dishwasher won't start. I don't know if it's the door switch or the Selector Switch Assembly. As with everything
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher On/Off Switch
  #1 (permalink)
Old 10-28-2010, 08:59 PM
Junior Member
j2mills is on a distinguished road
Default Bosch Dishwasher On/Off Switch
Model Number: SMU4056UC/14   Brand: Bosch   Age: More than 10 years
As with everything electrical / mechanical it was working just fine, and then........IT WON'T START!
We had a problem with the selector buttons sticking and not changing cycles (rinse-hold to regular wash).
When pressed the power button does not turn red as it once did.
Is it the Power Button or the Door Switch? How do I remove the front panel to check?
Thanks,
j2mills
Related Models
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
Amana SNP26CB RANGE- S/I STD GAS
Amana SNP26CB0 RANGE- S/I STD GAS
Amana SNP26CB5 RANGE- S/I STD GAS
Amana SNP26ZZ RANGE- S/I STD GAS
Amana SNP26ZZ0 RANGE- S/I STD GAS
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A REF - SXS/I&W
Amana SP17A-A REF - SXS/I&W
Amana SP17A-AG REF - SXS/I&W
Amana SP17A-C REF - SXS/I&W
Amana SP17G REF - SXS/I&W
Amana SP17G-A REF - SXS/I&W
Amana SP17G-AG REF - SXS/I&W
  #2 (permalink)
Old 09-08-2011, 05:56 AM
Junior Member
shak is on a distinguished road
Default Bosch SMU4056uc/14 dishwasher broken wire
Just had the same problem on this exact model...it was the black wire that comes from the terminal block to the on/off switch. It broke in the harness at the point where the door opens.
The opening and closing of the door over time causes the black power wire in the gray harness cover to break.
turn power off at breaker panel first !
Too get at it: remove kick panel(s) then remove front door panel (six stainless steel screws,three on each side, on INSIDE of door not the door edge trim screws. have a helper hold the front panel in place while removing these screws..cause it will drop to the floor if you remove screws with the door all the way open.)
At this point you should see the gray harness cover. it is a flat 3"X12" (approx.)vinyl piece sewn together over the wires to protect them. You may have to remove the brace that goes over it in the door and some sheet metal covers near the terminal block on the lower body where the power comes in...but you'll see what needs to come off when you get in there.
Look the gray cover over carefully front and back...if this is your problem you will see a burnt section on the gray cover where the black wire heated up and broke. This is the second time I've repaired it...first time I used a butt connector and taped it...this time I sliced the gray cover lengthwise and ran a new black wire from the terminal block all the way to the on/off switch. Note the writing on the black wire...use exactly the same gauge and heat rating. Tape up the gray cover and reassemble...took about 30 minutes total. Now would be a good time to lube those sticky buttons too! I used a tooth pick and some white lithium grease very sparingly!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher on/Off switch will not stay on absqrd Dishwasher Repair 0 04-25-2010 01:38 PM
Bosch dishwasher float switch Steve A Dishwasher Repair 14 10-12-2009 07:33 PM
Bosch Dishwasher On/Off Switch Stuck Martinlady Dishwasher Repair 0 10-10-2009 07:53 AM
Flow Switch Location on Bosch Dishwasher Steelerman Dishwasher Repair 0 05-09-2009 10:26 AM
Bosch Dishwasher Flow Switch jkkoerner@gmail.com Dishwasher Repair 0 04-03-2009 05:29 AM
