| » Whirlpool dishwasher no water heating or drying |
Model Number: GU1500XTLB1 Brand: Whirlpool Age: 5 - 10 years
No water heating or heat drying in dishwasher. Water heating light does come on on control panel. Element, thermostat or is there are water temp sensor in this model? I couldn't find reference to one in the diagrams. Thanks if yiou can help or even if you can't.
Replacement parts for WHIRLPOOL GU1500XTLB1 Undercounter Dishwasher | AppliancePartsPros.com Here is a manual which should help sort this out. https://secured.whirlpool.com/Servic...LE/8178022.pdf Element, thermostat or is there are water temp sensor in this model? Thermostat is a hi-limit Item 30 in Section 7 of the parts Temp sensor is a thermistor Item 25 in Section 8 If the cycle times are normal I would start with the thermistor. The unit thinks the temperatures are OK so progresses merrily through the cycle. If the cycle times are longer, I would remove power from the unit and check the thermostat and heater with a meter. The unit is waiting for the water to get to set point it does not but there is usually a default time where the unit will continue the cycle. Be sure to disconnect one side of the device you are checking this prevents you from reading an alternate/parallel circuit path. Thermostat should be 0 ohms and the heater about 20 ohms.
__________________
| Display Modes | |
| Whirlpool dryer heating but not drying | goochrl | Dryer Repair | 3 | 07-13-2010 11:45 AM |
| Whirlpool duet heating,but not drying | pdamanbtcc | Dryer Repair | 1 | 10-13-2009 04:16 PM |
| Whirlpool Electric Dryer not heating/drying | GeminiDreams | Dryer Repair | 3 | 06-16-2009 03:52 PM |
| whirlpool dryer heating but not drying | ksimager | Dryer Repair | 1 | 06-04-2009 01:56 AM |
| whirlpool dishwasher not drying dishes | jr2858 | Dishwasher Repair | 5 | 05-21-2009 09:44 AM |
