The door started to leak and thought it might be the rubber gasket. Replaced that, but still leaked. Took the door apart and discovered the bottom of the inner door is cracked on both corners about 2". I can't figure out how to get the vent housing assembly off the door to remove the wires so I can replace the inner door. How do I remove the vent housing assembly?
