Help!!!! The soap dispenser door on my dishwasher will not open during cycle. I have cleaned dispenser door with no luck.:mad:
THIS FORUM IS DEAD!!!!!!! |
:confused: Denman, My son and I have taken the push nut off by bending it away from the housing just enought to get some dikes behind it and cut it and twist it off, we know that the teeth were faceing toward the housing The shaft did pull out about a 3/8 of and inch and I think that it came free on the inside but I pushed it back in and it does not spin. I did try to see if it would rotate back and forth but it seemed to be stationary and not rotate at all. I also messed up and didn't take any pictures before we disassembled the area to show us witch way the springs were attached. I think that we have a shot at remembering but are there any pictures out there that can be sent to us and do we have to replace the pump if the shaft apears to be statioinary? I don't think that it rotates at all but I am not sure yet but it doesn't spin by hand anyway. Is that good or bad? We ordered the parts and put the machine back into the cabnet out of moma's way until the parts get to us and we can try again. I guess we will find out then anyway, but still, if we can get some pictures and glean some other information from you good folks it will help us. Take care Ken and Son
