Here are your parts. Your model number seems to be short a couple alphanumerics.
Replacement parts for GU1500 models | AppliancePartsPros.comYes, it could be the heating element is shot.
Remove power from the unit.
Remove the kick plate.
You may also have to pull the dishwasher forward.
Measure it with a meter.
Not sure what it should be usually around 25 ohms.
if OK
Check the hi-limit thermostat (Item 30 in Section 7).
Should be 0 ohms
if OK
Remove the doors inner panel and check the wires going from the control board to the heater
if OK
Odds are that the board is shot.
