Discuss
Dishwasher will nor drain
 in
Dishwasher Repair
Dishwasher will not drain. At the end of the cycle there is still soapy water at the bottom. I pushed
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher will nor drain
  #1 (permalink)
Old 10-20-2008, 12:07 PM
Junior Member
juliehoro is on a distinguished road
Default Dishwasher will nor drain
Brand: Whirlpool   Age: 1 - 5 years
Dishwasher will not drain. At the end of the cycle there is still soapy water at the bottom. I pushed the Cancel button to drain and it doesn't.
Ads By Google
  #2 (permalink)
Old 10-20-2008, 02:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if there is power to the dishwasher. What is the complete model number of the dishwasher?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-17-2012, 02:58 PM
Member
ramblinche81 is on a distinguished road
Default Soapy water in bottom after cycle completes
I am reviving this thread because my search came up pretty empty for ideas.
Maytag MDB6600AWS installed 2004 with no issues except door handles and now this.
We use Cascade, Publix, Generic gel for several years with no issues until last week. Only fill one side of reservoir so I don't think over soaping is problem.
Have heavy foam in bottom. Think about a kids bathtub with bubble bath after a rinse down
Only user issue of late is I found one half of a rigid plastic sipping straw. I have to believe the unit chewed up the straw down to half size. Would plastic shards / debris impact pump down enough to leave foam ?
If I have to tear down the bottom agitator spinner section, any suggestions before I ruin something ?
  #4 (permalink)
Old 12-17-2012, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
There are two most common causes for foam and/or bubbles inside a dishwasher. They are: 1. spilled rinse aid or broken rinse aid dispenser and 2. hand washing detergent not rinsed completely after prewash or accidentally filled into the dispenser.
You can try to add 2-3 tablespoons of vegetable oil to break the soap up and run the dishwasher a few times to wash it out. You also may want to use a product called Dishwasher Magic to clean the sediments and sanitize the dishwasher.
__________________
  #5 (permalink)
Old 12-17-2012, 04:38 PM
Member
Default Soapy Water Bottom of Dishwasher
Gene, thanks for suggestions. I had not considered regular dishwashing or liquid handsoap finding its way into the washer as a problem. Certainly possible since we almost always are handwashing in the sink and in the automatic dishwasher.
We don't use rinse aid so that shouldn't be an issue.
I'll see if it washes through in the next couple cycles and see where it goes from there.
Last edited by ramblinche81 : 12-17-2012 at 04:40 PM. Reason: Add note about rinse aid for clarity
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher will not drain Stardell Dishwasher Repair 2 12-21-2009 12:05 PM
Dishwasher will not drain GoBlue Oven Repair (including Ranges and Cooktops) 3 08-19-2009 11:21 PM
Dishwasher won't drain Ikekey Dishwasher Repair 0 06-12-2009 08:20 PM
Dishwasher does not drain iwen Dishwasher Repair 0 03-14-2009 12:01 PM
dishwasher won't drain sandmancan Dishwasher Repair 0 12-25-2008 09:10 AM
