| » Electronic Control Panel or Touch Pad Control Issue? |
Model Number: 665-16463300 Brand: Kenmore Age: More than 10 years
Have Whirlpool designed Kenmore, Elite Dishwasher Model 665-16463300. Have power to unit. Door switch tests OK, Thermal Fuse tests OK. Touch Pad only lights up on the three "OPTIONS" buttons in center of Touch Pad, for approximately 30 seconds. 6 Bottons to the left ot the Touch Pad marked as "CYCLES" and 3 buttons to the right marked as "DELAY HOURS", "CANCEL/DRAIN" and the "START" buttons will not light up and the diswasher does not start.
Dishwasher worked fine, went to use it again and only center pad will temporarily function. Unit is nearly 15 years old, but used only 20 times over it's life. Still like new. Is problem most likely the Electronic Circuit Board behind the Touch Pad, or is it in the Touch Pad alone? Lou Ads By Google Related Models |
| Display Modes | |
| Control Panel or Touch Pad Control Issue? | maxtout4u@aol.com | Oven Repair (including Ranges and Cooktops) | 0 | 10-08-2010 11:19 AM |
| sensor issue vs electronic control | curiousjo | Oven Repair (including Ranges and Cooktops) | 0 | 09-24-2010 12:58 PM |
| No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board | hddman | Oven Repair (including Ranges and Cooktops) | 0 | 04-26-2010 12:09 PM |
| Control Panel or Electronic Control - which causes blinking panel lights? | MarcLCH | Dishwasher Repair | 1 | 02-25-2010 03:25 AM |
| control panel touch pad | catcar | Oven Repair (including Ranges and Cooktops) | 1 | 02-19-2010 06:42 PM |
