Discuss
Water Leak Boot part # 505
 in
Dishwasher Repair
I have replaced part # 505 the boot at the rear of the Dishwasher. I do not have a water leak
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Water Leak Boot part # 505
  #1 (permalink)
Old 09-27-2007, 07:46 PM
echen echen is offline
Junior Member
echen is on a distinguished road
Angry Water Leak Boot part # 505
Model Number: GSD4310   Brand: GE   Age: 5 - 10 years
I have replaced part # 505 the boot at the rear of the Dishwasher. I do not have a water leak when the washer is filling with water. When the motor/food grinder start water leaks from the side of the boot. Does the boot need to be silconed in place?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-28-2007, 11:07 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi echen
The inlet sump (you called it "boot") does not need a silicone or any other kind of sealant. It has to be installed in the right way with the sump cap (#508 on the dish washer body break down diagram) in place and the sum cover (#506 on the dish washer body break down diagram) attached on the top with the two screws holding everything together.
If all of these parts assembled in the right way, it's not suppose to leak.
Also check the clamp were the pump inlet comes into the sump under the dish washer (#452 on the wash system break down diagram). It might be loose or the pump inlet inserted improperly.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water leak in ice maker Brown4repair Refrigerator & Freezer Repair 2 12-23-2007 04:27 PM
replacing drain boot/elbow #WD18X213 rsy Dishwasher Repair 1 09-18-2007 08:54 PM
water leak from Ice dispenser tsherman Refrigerator & Freezer Repair 0 09-02-2007 02:31 PM
bOOT RE-INSTALL m1964 Washer Repair 0 08-05-2007 06:36 AM
what part do i need? agitator Washer Repair 1 07-27-2007 05:45 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
