Hello, my Tappan dishwasher is not draining. I've checked the drain hose, the hose going to the pump, and the pump. I also took off the spray arm and filter and checked for any clogs. Everything looks clear. I watched the drain hose going to the sink while the washer was in the drain cycle. There is water going through the hose. There are a lot of air bubbles. I hear a lot of air coming out of the air gap. The air gap did not seem to be that noisy when the washer was working properly. Then when the drain cycle ends, I see some of the water in the drain hose go back into the washer. Any suggestions? Thanks for your help.
