The heat is not working at the end of the washing cycle to dry dishes. Any suggestions on where to start looking for problem?
Thx
Originally Posted by: Woody W The heat is not working at the end of the washing cycle to dry dishes. Any suggestions on where to start looking for problem?
Thx Woody, A model number would help, a lot. You need to start at the heater element and hi limit thermostat on the bottom of the tub, behind the kickplate and lower access panel. You may be able to find the technical data sheet on the backside of the kickplate (if it hasn't been removed / lost) and run the test mode listed on it. :cool: :cool: :cool:
