| » Control Panel Removal |
Model Number: SHU5312UCU06 Brand: Bosch Age: 5 - 10 years
I need to replace the plastic control housing and must take off the plastic control cover to do so. How does the control panel come off? How do I remove it (is it screwed, snapped, etc). No screws are evident, but may be hidden?
Related Models |
Hi PeteME
I'm assuming you already removed the fascia panel . Remove one screw on each side of the inner door panel holding the controls bracket and pull it out as far as wires go. The housing for the control module has three tabs on the bottom. Push them up and in and push the housing inward. Now you can replace the housing. Good luck. Gene.
__________________
Professional appliance repair in Orange County, California. |
| Display Modes | |
| Control Panel Touch Pad not working | rtismeer | Washer Repair | 6 | 09-08-2008 11:30 AM |
| Do I have a bad control panel? | wenoch01 | Oven Repair (including Ranges and Cooktops) | 4 | 11-05-2007 05:51 PM |
| Control Panel lockout | Washman | Dishwasher Repair | 8 | 10-08-2007 10:00 PM |
| Maytag Dryer front panel removal | jkbatt | Dryer Repair | 0 | 08-23-2007 07:49 AM |
| Replacing Control Panel | bhandg | Oven Repair (including Ranges and Cooktops) | 2 | 07-23-2007 05:30 PM |
