The soap dispenser door does not open when the dishwasher goes through its cycle. Everything else works fine.
I believe that the part I need to replace is AP4110779.
Is there a way to check to make sure this is the broken part before ordering it? For example, checking it out with an Ohm meter or ??
Thanks.
